Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 08-04-2011, 01:01 AM
Dagger99 Dagger99 is offline
Rear Climate Control
After installing an aftermarket stereo in my 2003 Montana (with stock rear Dvd system) I have lost all control of the rear climate controls. Has anyone ever found a work around to regain control of this function?
Old 12-07-2011, 10:48 PM
Re: Rear Climate Control
Removed aftermarket stereo and installed the original factory radio. The rear climate control still says disabled even after the switch is set to "R". Could I have shorted something out? Oh and by the the way, I cant get any heat from the rear blower. It only blows cold.
Old 12-07-2011, 11:35 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
I'd say check all wiring around your installation and removal, pinched wires, unplugged or loose connections, screw(s) run through wiring, fuses. Check everywhere that you were when you installed the system.
stereo wiring & dual climate control enslow LeSabre 21 06-27-2011 04:40 PM
Unable to adjust climate controls..? ArdiniA Caprice 3 01-06-2010 09:05 PM
AC/Climate Control '02 Silhouette (Venture) andante147 Venture 0 06-24-2009 02:47 PM
Rear climate control not heating 04 excue2 Suburban 1 02-22-2007 08:41 AM
2003 Yukon leak through rear climate control panel chris_yukon Eastern US 0 12-29-2003 03:10 PM
