Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 08-03-2011, 10:39 PM
61impala5150 61impala5150 is offline
1997 tahoe engine problems
so the egine in my tahoe has a miss sitting still all the way to sixty. i have installed a new distributer,cap,rotor,wires,plugs,coil and a new pcv valve. it is still missing. the miss is not consistant, but very noticeable. i have hooked my scanner to it and got a p1345 correlation problem code and o2 heater diffeciency code and o2 sensors code. could the o2 sensors make it miss like it is or could it be the fuel spider. i need some help with this one, its got me stumped
Old 08-05-2011, 11:10 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1997 tahoe engine problems
What engine?
You need to set the camshaft retard setting [corelation] with a engine capable scanner.
Set it within 1-2 neg or pos degrees as close to 0 degrees as you can get it.
What is the camshaft retard reading at now?
Has the dist been removed or changed?
What are the 02 sensor code no?
MT
1997 Tahoe engine revs then dies in park dollarbillHCCA Tahoe 1 11-08-2007 09:27 AM
1997 Tahoe - Fuel Pump noises/problems gasmith Tahoe 1 08-25-2005 06:22 PM
1997 Tahoe power problems poonjahb Tahoe 7 07-12-2005 08:46 AM
98 Tahoe Engine Problems khtrombone Tahoe 4 05-14-2005 12:47 PM
1997 tahoe LEFT TURN SIGNAL problems dave7519 Tahoe 0 02-08-2005 11:05 AM
