Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 08-03-2011, 07:49 PM
samahi72 samahi72 is offline
96 Maxima - Occasionally dies while driving
This is my wife's car and on at least two occasions, the car has died when she let up on the gas pedal. It was hard to start after that. The first time it did not kick out any codes. Today it did. The codes were PO100 and PO325. The 100 is for the MAF sensor and the 325 is a knock sensor in Bank #1 or Sensor 1.
I know some malfunctions will cause erroneous trouble codes and I don't want to throw money away on good parts.
The car has just at 100k.
Any ideas?
Thank you
Old 08-03-2011, 09:05 PM
danielsatur danielsatur is offline
Re: 96 Maxima - Occasionally dies while driving
Because of age + mileage have your catalytic converters check at any local muffler shop.
Old 08-03-2011, 09:12 PM
tempfixit tempfixit is offline
Has the MAF sensor ever been cleaned if not get some maf sensor safe cleaner and give it a try, also I would check and clean Idle Air Control Valve.
Old 08-04-2011, 01:22 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Any ideas?
Thank you
MAF. (Knock sensor just affects ignition advance, exhaust can kill engine less than spare tire...) To test MAF when the problem is ON, just disconnect...
Some shops advertize under 100$, like http://www.driven2automotive.com
However, always before any electronics swap, test first charge voltage - at batt. And clean the connectors...
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 08-04-2011, 10:02 AM
1) Clean MAF/IAT sensor with CRC MAF sensor cleaner.
2) Do a Google ''Youtube Auto MAF test''
3) Have both the battery + alternator load tested for free at any local auto parts store
A plugged catalytic converter can choke an engine out, a simple test canbe done free & rule it out.
4) Do a Google ''Youtube Auto catalytic converter test''
5) Fuel pressure test.
Old 08-04-2011, 12:01 PM
If pump and/or its pwr fails - truly engine dies. And this problem can be intermittent as depicted, very rare compared to MAF. This is comparable to intermittently failing worn ign switch or whatever pwr failure...
Fuel pressure indicators when the problem is ON:
While engine is being cranked - and nostart - there will be noticeable gas smell. Even wifey will tell about this: This means that gas pump works up to a point... Also the gas hose is stiff when pressure is up, do feel it near the fuel filter under hood. (just indicators)
Old 08-06-2011, 06:00 AM
Thanks for the You Tube suggestion. I am a real visual person and seeing others do it first really helps.
Old 09-15-2011, 08:32 PM
fluor fluor is offline
Angry Re: 96 Maxima - Occasionally dies while driving
Hi!
I just have same symptoms (P0100 and P0325) after my car was rearended. Is this the result of collision? Help anybody!
Old 09-16-2011, 06:35 AM
Originally Posted by fluor View Post
Hi!
I did replace the MAF and the IAC. So far it seems to have solved the problem. Sorry to hear about the accident.
94-S10 - Dies while driving and other misc. wacky problems avlind S-10 4 09-30-2010 06:18 PM
'94 3800: dies while driving... jarl Trans Sport 5 11-29-2009 11:50 PM
2000 malibu dying while driving appleblossom Malibu 4 03-13-2005 08:06 AM
Jeep Cherokee 89' Turns Over but dies, eventually starts and dies while driving. forester6779 Cherokee 2 12-24-2004 02:16 PM
engine died while driving hbatt0usai Grand Cherokee | Grand Cherokee SRT8 1 10-25-2003 04:23 PM
