Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 08-03-2011, 04:09 AM
Meridivs's Avatar
Meridivs Meridivs is offline
Lightbulb Time for a tune-up
It is time for a tune-up on our 3.1 TBI Pontiac TS SE.
The options for spark plugs (copper, platinum and so on), spark plug wires (classic, silicon-core, performance) and distributor cap are so many.
From your experience which would be the best choice in spark plugs/wires/distributor kit for this engine in terms of performance/fuel economy?
Thank you
Old 08-03-2011, 04:41 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Time for a tune-up
As a general rule, it's best to keep it simple.
Platinum plugs offer nothing in performance, but do have an increased life span.
However, some olders cars have been known to have problems with them.
So, stick with good old fashioned copper, simple plugs. Just make sure you get the right heat range for your vehicle.
Same with spark plug wires.
If your running an insane over power aftermarket ignition system then using thicker heavy duty performance leads would be a good idea.
If it's all standard then stick to standard leads.
Same with your dizzy cap etc.
The ignition system is actually very simple, but there are enough parts to it that are easily user replaced, that people like to "invent" snake oil fixes that don't really do anything but cost more.
Stick with the simple stock parts and you won't have any problems
The Following User Says Thank You to Moppie For This Useful Post:
Meridivs (08-03-2011)
Old 08-03-2011, 06:50 AM
Meridivs's Avatar
Lightbulb Re: Time for a tune-up
That's pretty much my feeling but it's a good idea to ask before putting double the money into a premium tune-up.
If there's no performance/fuel economy gain from using more expensive Platinum plugs & premium wires then it seems wise to stick to the less expensive solution.
Any brand recommended for these engines (ACDelco, Champion, Denso)?
Old 08-03-2011, 09:56 AM
inafogg inafogg is offline
stick with the oem ac delco so you only do the job 1 time
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
The Following User Says Thank You to inafogg For This Useful Post:
Meridivs (08-04-2011)
Old 08-04-2011, 07:21 AM
500hpgtx's Avatar
500hpgtx 500hpgtx is offline
I used Bosch platinum plugs a long time ago, that did well. But in my opinion, over the years, I use only Autolite double platinum plugs.
They last a very long time. I do not lok forward to changing them on either of my 3800 engines. On my GTX, I use 3 heat ranges colder. They still last, even when blasted by a 150HP nitrous shot multiple times. Just my experience. Good Luck...
Old 08-04-2011, 08:15 AM
Jrs3800 Jrs3800 is offline
In this case, stay with the AC Delco parts if at all possible..
Need recommendations for tune up krushmoto Caravan | Voyager 2 09-13-2006 05:44 AM
91 S10 need computer for tune up? shawnira S-10 0 08-07-2006 08:09 PM
Time to tune up? regalfriend Grand Prix 1 04-23-2006 01:59 PM
Best Plugs / Wires for Tune up??? Buda Accord/TSX/Accord Hybrid 5 06-17-2005 08:27 PM
Tags
plug , plug;spark , tune , up;ignition;spark , wire;
