Old 08-02-2011, 10:15 PM
doug2060 doug2060 is offline
Anyone want to help me with an experiment? Have a 1997 1998 or 1999 Cavalier/Sunfire?
I believe my PCM is dead. Before I spend the money to get one and have it programmed I was hoping someone would volunteer to help me or maybe even know the answer.
I'm hoping someone could disconnect their battery and unplug both harnesses from their PCM then re-connect their battery and turn the ignition on and try to crank etc and post the results.
I have tried everything I can think of to resolve my issue. I have traveled to the end of the internet. I have seen many wiring diagrams. I have tried and tested every fuse, relay, wire, and fusible link but still no luck. All I have is a good battery providing proper power to a brand new ignition switch but when I turn it I get nothing. No clock on the radio. No lights on the instrument cluster. No power to the starter or anything past the ignition switch. When I open the door the dome light comes on. The horn blows. The emergency flashers work. The headlights come on. The key even ding ding dings when I put it in the ignition. I can't even scan for codes.
Is anyone with a 1997 to 1999 Cavalier or Sunfire willing to try this?
I have started threads on many forums with no luck.
If you are willing to help please let me know. I'm broke and can't afford to throw money at it.
Old 08-03-2011, 06:31 AM
brcidd's Avatar
brcidd brcidd is offline
Re: Anyone want to help me with an experiment? Have a 1997 1998 or 1999 Cavalier/Sunfire?
Why did you replace ign switch? There-in probably lies your problem.
No lights on instrument cluster means no power there....so did first switch burn some contacts? in the wiring connectors? PCM would not control instrument panel power.....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 08-03-2011, 11:53 AM
There was nothing wrong with th e first switch.
Old 08-21-2011, 03:26 PM
Tech II Tech II is offline
Go to your fuse block....turn key on....using test light, are all your fuses getting power, or are there a lot of them with no power?
Old 08-21-2011, 03:28 PM
Thanks for your help. I found the issue a while back. One of the main power wires going to the ignition switch shorted out in the harness block under the hood behind the air filter housing.
1999 Cavalier Wheel bearing problem RobbWis Cavalier Problem Diagnosis 0 04-30-2011 01:15 PM
1997 1998 1999 transmission differences? ford f150 2x4 bjrjr16 F Series 0 04-15-2010 03:54 PM
cavalier 99 cooling fan drtyrocker Cavalier Problem Diagnosis 3 07-01-2009 08:08 PM
Help with Programing keyless entry 1998 Grand Cherokee riverperson Grand Cherokee | Grand Cherokee SRT8 4 07-16-2004 04:31 PM
