Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Brakes and Suspension
Old 08-02-2011, 12:54 AM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
Junkies back! Need some help with build..!
Hey guys, been a long time...I see a few familiars!
I have come a long way during my FULL build, had set backs, like the time that I had the motor all together and ran the car but it knocked still, only to find out that the machine shop gave me the wrong bearings, after waiting for about 7 months to get my machine work done. Finally found a much better shop with great prices and quick turn arounds. Anyways, after all is said and done, I finally have the $$ to buy the last few parts I need, including a new clutch.
If anyone wouldn't mind donating some knowledge, I have a few technical questions about some things just before I start ordering a wave of parts.
Suspension:
(1)-Ok, all I need to know is where I can find good deals on the rear suspension components. I found an entire kit on ebay for the 420a cars, but its only the complete FRONT suspension kit. Nothing for the rear. Not even individual pieces..For the rear I'm seeking trailing, toe control, lower and upper arms. Id rather avoid the stealership, if possible. Anyone ever seen anywhere online that has these parts for a good price?
(2)-How often do the knuckles need to be replaced? During the life of the car..
Brakes:
Alright, rack your brains. Im doing the rear drum to disc conversion. I have searched, searched, and searched more bc all how-to's conflict with each other, and contradict one another. I have most of it figured out except a few things.
(3)-One site says you must replace the knuckle on both rear tires...is this true? Or will sourced backing plates fit right on our stock knuckle?
(4)-Brake lines- if I have the rear brakes changed to discs, which ss lines kit do I order? Are all the ss lines for all the model eclipses the same? Are there differences? Need two for front obviously, and two for back, considering rear upgrade.
(5)-Front GSX upgrade- I wanna do the dual piston caliper upgrade on the front, which consists of a swap from a GSX. Do I use same size rotors that came on my car or does this mean I also need rotors sourced from a gsx? If so, what else? And again, which ss lines do I need for the new gsx dual piston calipers?
I know it's a lot of questions, but anyone who has done these things already should be able to answer them easily. I'd really appreciate it if people would answer whichever ones they can with whatever you know..Thanks guys
P.S.
(6)Are all 4 wheel hubs assemblies the same? Or do the rear hub differ from the front hubs? You have to replace the whole hub right? Can't just do the wheel bearing...or so I'm told.
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 08-02-2011, 08:24 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Junkies back! Need some help with build..!
You can do just the wheel bearing, I did it once before. It's a complete PITA though... Brakes... Well here is my thoughts since you are converting to rear disc and upgrading your front calipers... I would use front and rear stock brakes off of a GSX for your upgrade. Not sure if you will need to replace the rear knuckle or not... But anyways... Then you can just use ss brake lines from an AWD model for your car. The only difference you need to watch for is ABS or non-ABS... Also, check to make sure your proportioning valve is the same from FWD to AWD. If not, you will need to change it as well to compensate for the change in the brake setup... I would use the front disc off of the AWD as well if you upgrade to the dual piston calipers... Hope that helps some.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-02-2011, 09:22 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
For the GSX front
http://www.automotiveforums.com/vbul...d.php?t=739075
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-02-2011, 01:38 PM
From what I understand the prop valves on all models of eclipses have the same part number, so I think i'm good there. My only other question is, can I sub out using stock rotors from a GSX for using upgraded rotors from a GSX...I can't see there being a difference...you know like if I wanted a nice set of drilled and slotted ones instead of stockers. In which case the front rotors would be from a GSX, and the rear would still be ones from whichever eclipse has rear discs. So wait a minute, are all the rear rotors the same on all the eclipses? Bc the swap says you can use any rotors for the rear from any other model eclipse, but only the GSX front ones for the front upgrade. Weird
Old 08-02-2011, 06:17 PM
You can use aftermarket GSX rotors and it'll be the same as stock size unless you buy aftermarket rotors for a big brake kit. Just make sure you watch for the difference. Although I'm sure you'll notice it in the price jump... Oh and the proportioning valves are definitely different between ABS and non-ABS models. I had to change mine when I removed the ABS from the Talon.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-02-2011, 11:15 PM
So, with what im doing, I dont need to?
Old 08-03-2011, 06:40 AM
Do you have ABS now?
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-03-2011, 12:03 PM
I cant remember, and I cant check right now, but im fairly certaint he last time I worked onthe front suspension I didnt see any sensors
Need some help with some performance stuff PBRoy Performance 1 02-09-2010 06:27 PM
Need some help with a 1996 eagle talon!!! PLEASE HELP talon_17 Off-Topic 1 10-02-2006 07:47 PM
I need some help with my springs Xxcivicex1169xX '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 12-09-2001 11:04 PM
