Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 05-30-2003, 10:18 AM
kennewickman kennewickman is offline
86 Mazda 323 w/FI died
Yesterday car started up normally. drove it for about 2 miles then it died suddenly (like you turned off the ignition).
Cranks ok. Timing light indicates no spark.
Swapped Dist cap and rotor - no effect
ignition coil continuity and resistance seems normal.
I'm thinking that it might be the igniter, but not sure.
I noted that Tach does still indicate when cranking engine.
Is igniter the likely culprit or am I completely out to lunch?
Thanks,
Old 07-09-2003, 01:36 AM
bassmekanik bassmekanik is offline
i gather u have tested all the spark plug leads for spark?
is there power to the coil?
fuses?
does all the dash lights come on when the ignition is on and the engine stoped?
Alpine CDA-7892E head deck
Us Audio USA-1000DX and USA-554 amps
Alpine SWS-1040 Subs X2
Alpine SPr-175A
More gear coming soon
Old 07-09-2003, 10:37 AM
Solved
Thanks for the reply,
Problem was a shorted rotor. Yeah, the first replacement had a low resistence too.
It's running great now.
1992 323 Electrical/computer problem Lilautoworker 323/Protegé/Familia/Etude/Allegro 1 06-22-2010 05:22 AM
Awsome mazda 323 forum Net Seven 323/Protegé/Familia/Etude/Allegro 9 05-03-2003 07:07 AM
1992 Mazda 323 - Head gasket leak and other things... srossign 323/Protegé/Familia/Etude/Allegro 0 03-10-2003 02:24 PM
Mazda 323 - 1992 xuamox 323/Protegé/Familia/Etude/Allegro 1 03-10-2003 02:20 PM
1988 Mazda 323 for sale HondaSi88 General Discussion 0 07-06-2002 11:40 PM
