Read lots of posts but none for a 91 Bonny sse. Is the BCM located under the relay panel ? The fan wire harness goes under the relays. Just need to know if it is under the hood. I have the cover off the relay panel but don't see the module. Really appreciate your help,the **&^%% fan will not shut off.Had to disconnect the battery cable.
Re: blower control module location
It is here, held in by some 7mm screws:
![]() Under all of this: ![]() A cover and a couple of 10mm nuts, one on each end of the relay center, should allow you to move the relay ceter forward enough to access the blower module. You will have to move the wires on the vacuum tank end to get to the nut. Disconnect negative battery cable first, there is a big hot wire bolted to the top. |
Found it ,got it! Now to find one that will fit at the bone yard.I understand the a lot of models used the same module. Thanks for your help.
Found one at local yard off a 92 Cady fleetwood. The heat sink was alittle different but it worked just fine. Just thought I would pass the info on.
This is a great web site,people really help each other.Thanks again. |
