Old 07-30-2011, 02:39 PM
crustyalero crustyalero is offline
Hazard light switch fell into dash
I have read that other 2001 Aleros have had this problem. There is a plastic piece that holds the hazard light assembly. That piece screws into the dash with three screws. It appears that part of it has broken off so that it no longer holds the hazard light assembly at all. I can slide the assembly back in, but it would just slide back into the dash when pressed.
Is it possible to buy that plastic piece somewhere?
I have read where someone put a dob of super glue on it and put it back in. However, if I did this, I would not be able to replace the flasher connected to the back of the button if it went out - would I? My wife is pregnant, and I may need my hazard lights in the near future, so I want to fix the problem and not cause another one in the future if I need to replace the flasher.
Thanks
Old 07-30-2011, 02:48 PM
procaddytech procaddytech is offline
Re: Hazard light switch fell into dash
Sure you would be able to replace it. If you glue it to the broken retainer, replace them both when and if the time comes, that is if it is available separately. You may want to call around. Is this the piece you are talking about:
Old 07-30-2011, 05:42 PM
Yeah, that's it. The black plastic thing with the three screws in it. The thing the hand is holding in the picture.
Any idea how hot glue would hold? It could be easily cut away. I'm just now sure how it would hold up in a closed up car in the sun. ...Not sure at what temperature hot glue melts.
I thought about taping it up, but the heat would get the duct tape or electrical tape... I think.
1997 Cutlass Supreme SL Hazard Lights Help fonzie9 Cutlass Series 0 11-26-2010 09:24 PM
98 1500 hazard light switch hoot972 C/K 2 04-30-2010 10:12 AM
Hazard light switch 'fell' into dash silvertree Alero 4 06-13-2009 11:59 AM
Hazard light switch part number cleong Intrigue 5 04-11-2009 02:20 AM
96 bravada hazard light switch nockam Bravada 1 01-04-2005 02:04 PM
