chevy AC problems
Re: chevy AC problems
Sounds like the charge is very low or the orifice tube is completely stopped up. I would geuss low system charge first especially if the high pressure is also low.
so how do i fix that?
find out how much to put in to the system...what was the high side pressure and what is the air temp at this high side pressure..
if you cannot read high side pressures you have no idea whats going on ! |
Was the system vacuumed off? Did you just stick another can of freon in it?
Matthew Brough ![]() 1997 Geo Prizm -- 301,000 miles 2000 Honda Accord -- 225,000 miles 2004 GMC Yukon XL -- 223,000 miles 1987 Jeep Comanche -- 116,000 miles |
hey, sorry I haven't had time to reply i found out that i just needed to add another can of freon and sadly i discovered that it must have a leak in the system because a couple days later it doesnt work again. so ill have to get some that has the leak sealer in it thanks
That stuff will seal it up for sure wher it will never work again. Like stop up verything. ![]() ![]() Gum up orfice tube and compressor and evaporator and condenser an what ever oil the system has in it. Best to find the leak and fix it.
185% agree! Get the stuff with the dye in it and get a black light and chase down the leak.
If you do this can damage your system and in most cases not stop the leak. USE THE LEAK DETECTOR DYE TO FIND LEAK ! POST BACK WHAT YOU FOUND . |
