Old 07-29-2011, 02:25 AM
McLin's Avatar
McLin McLin is offline
which Oil I can use?
Hi,
I don't want begin an discussion which Oil can I use for an 98's 3.8L Lumina?
The Price are 5W30: 12,99 and 5W40: 22,90 the number after the W tells me something about the oil if the engine is hot, but what is better 40 or 30? Or safer for my engine.
Best regards McLin.
My Lumina
My Girlfriends Lumina
Mileage:
Old 07-29-2011, 05:57 AM
procaddytech procaddytech is offline
Re: which Oil I can use?
From GM 98 Lumina service info:
• For the 3800 L36 (VIN K) engine, SAE 10W-30 is the recommended viscosity. However, 5W-30 may be used if the outside air temperature is lower than 16°C (60°F). Do not use other viscosity oils, such as SAE 20W-50.
Old 07-29-2011, 08:55 AM
McLin's Avatar
GM said too we should just use Dex Cool... And the result was broken LIM gasket.
Best regards McLin.
My Lumina
Mileage:
Old 07-29-2011, 11:00 AM
jamesmetairie jamesmetairie is offline
Originally Posted by McLin View Post
Hi,
my 1998 lumina 3.1 had 45,000 on it when i bought it and has 155,000 on it now. i have used 10w30 for 9 years. no problem in the Louisiana climate.
Old 07-29-2011, 03:41 PM
maxwedge maxwedge is offline
A990 racer
Irrelevant to the "maybe" Dexcool issue, 10/30 as stated.
Old 07-29-2011, 07:39 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Motorcraft or Valvoline 10w30 semi-syn all it's life, 162,000 now, runs like new.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 08-01-2011, 12:56 PM
rkvons's Avatar
rkvons rkvons is offline
The gaskets broke because they were defective, not from DexCool.
Old 08-01-2011, 07:15 PM
Thank you. My thoughts excactly.
Which oil to use? Toolwise Bravada 7 08-31-2006 01:02 AM
need a motor, i have a quick question about which i can use roadxing Ranger | Courier 0 08-14-2006 08:35 AM
Which gear oil to use??? Please advise! grumpee Engineering/ Technical 1 08-10-2003 11:03 AM
Which Oil To Use afundora 7 Series 3 10-08-2002 12:32 PM
Which oil filters are you guys using and..... TypeR Integra 8 07-04-2002 11:58 PM
