Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 07-29-2011, 01:13 AM
cuda1979 cuda1979 is offline
head gaskets will not seal
hi i have a 99 rodeo with the 3.2 and i am having a problem with the head gaskets not sealing i just rebuilt the engine and used all new parts i did have to have it bored out 20 over it runs great and sounds great it just has this overheating problem i have changed the head gaskets two times i can see with my bore scope that the coolant is leaking from the head gasket from more then one spot that is why i do not think it is a cracked head i torqued the new head bolts to 48 foot pounds with oil on the threads and it is still leaking if anyone has any thoughts please post them the one thing that i can think of is do the head bolts need to be torqued down more?
Old 07-29-2011, 03:05 PM
danielsatur danielsatur is offline
Re: head gaskets will not seal
Did you use a torque procedure?
Are you using new head bolts?
What about streach head bolts!
48ft lbs. sounds like the 1st step, see www.alldata.com
Old 07-30-2011, 12:16 AM
hi yes i did use the torque procedure and i did use new bolts and i agree that 48 foot pounds does not sound right i got the service info from michell on demand but i will check out alldata thanks
Old 07-30-2011, 12:44 AM
Cat Fuzz Cat Fuzz is offline
Torquing the head bolts is a two step procedure. First step, in proper sequence, is 21 ft/lbs, second step, in proper sequence is 47 ft/lbs. You should be using new head bolts, you should have the heads milled. Left and right head gaskets are not interchangeable. Left is drivers side, right is passenger side. Make sure the surface on the engine is super clean and super flat. If you went straight to the final torque on the first pass, you likely have warped the heads. It is also very important to remove the head bolts in several steps in proper sequence.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 07-30-2011, 01:18 PM
well i had the head checked last time and it was not warped i have been using new bolts but the service info i had did not say to do it in two steps which i thought was odd and i have been making sure everything is clean so i guess i will try again also i have been getting my parts from ebay but i think i will try a diffrent brand maybe felpro what do you guys think.
Old 07-30-2011, 01:31 PM
inafogg inafogg is offline
i have never had a problem with the felpro brand
what brand are you using?
do the leaks appear to be always in the same spot?
47 ft lbs does sound low maybe 47 + a torque angle spec but if your going off a manual i guess its 47
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 07-30-2011, 03:16 PM
i am using a brand that is from japan not sure what the name is and yes it is leaking inside the cylinders at the head gasket and like i said i thought that 48 foot pounds was odd too now that i have alldata it has a two step procedure and it is saying not to put oil on the threads so i will try it this way and see if that helps if not i would have no clue.
Old 01-13-2017, 01:26 AM
daddy2kids daddy2kids is offline
I experienced the same thing when i used a head gasket sealer a long time ago. My mistake was not reading the instructions to let it be for about 45minutes or more before driving the car.
It was just a minor engine oil leak, so we can repair it ourselves and save money. After following the instructions, there has not been any leaks.
Intake Manifold Gasket End Seals bjaymo3 Grand Prix 5 07-30-2010 08:29 AM
01 grand am 3400 head gasket? LoMbArD Grand AM 33 10-19-2009 12:29 PM
Head Gasket Leak el ratfink General Discussion 4 08-14-2009 06:04 AM
Intake gasket or head gasket?? mandymae104 Century 3 07-10-2009 09:31 AM
Replace head gasket or not? novicened Yukon 1 11-26-2006 04:18 PM
