Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-28-2011, 01:17 PM
country70 country70 is offline
88 camaro steering column problem
I have replaced an 88 steering column with an 84 column now the car wont fire. Everything matched up and connected. The only problem we had was that the horn wouldnt shut off so we disconnected it. Now the car wont fire.
Old 07-28-2011, 02:44 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: 88 camaro steering column problem
Just cause the wires are the same color doesn't mean they're the same (ground, power etc...)
Did you get the owners manual for both cars to be sure?
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 07-28-2011, 11:02 PM
No we didn't check the manual we were told 82-92 shoulda worked!! We have 84 project car and the column got busted in 88 so installed it!! It cranks but won't fire.
Old 07-29-2011, 06:19 AM
procaddytech procaddytech is offline
Did the 88 key have a Passlock pellet in it? Look for an orange wire coming out of the old column with 2 white wires coming out of it into a connector. If the 88 had theft deterrent the 84 needs to match it or the fuel injection may be disabled. There is away around it. Measure the resistance of the pellet in the key and use resistors to match it as closely as possible. Jump the resistors across the Passlock connector on the body side of the harness.
Old 08-02-2011, 01:33 PM
Ok we havent checked the wires but had to step away from the car for a few days it was making me angry. I will check the wires tonight if we get out to the farm. I was told I had to have an 88 column the 84 will not work. Can I rig it to work with jumping the resistors.
Old 08-02-2011, 02:16 PM
Yes, BUT you will not have Passkey theft deterrent because it will be bypassed. If you have content theft deterrent, where the horn honks and lights flash when the car is unlocked without the key or remote, that portion will still function, just not the starting disable portion.
Measure your key pellet with a DMM to get the most accurate reading you can. You need to match that resistance and jump it across the connector that the 88 lock cylinder plugged into.
Or you can take the 88 ignition lock cylinder out of the column, tape the key in it, plug it back in and tie it up under the dash.
Camaro steering column wiring kobra000 Camaro Discussions 0 04-09-2010 06:26 PM
steering column problems stephenp Camaro Discussions 1 05-30-2005 08:42 PM
steering column problem turbo ES Camaro Discussions 2 02-12-2005 06:15 PM
New steering column problem davcarter2000 Explorer | Explorer Sport Trac 1 12-18-2004 01:44 AM
