Old 07-25-2011, 08:42 PM
chngup chngup is offline
98 Pontiac Grand Prix GTP Steering Column Filler
Hey everybody, I'm trying to gain access to the temp actuator on the driver's side, I have a small diagram and some step by step instructions but I'm stuck at the steering column filler. The steps that I have say that there are 4 regular screws and possibly 2 smaller ones. I have removed 4 regular ones and the piece doesn't budge; I have tried to locate others but have not been able to as of yet. Can anyone give me some detailed assistance on removing this piece, thanks.
Old 07-28-2011, 09:47 AM
99kylec 99kylec is offline
Re: 98 Pontiac Grand Prix GTP Steering Column Filler
did you take off the tilt arm?
Old 07-28-2011, 11:40 AM
I didn't. The instructions I was following did not have that mentioned and it doesn't look to be a factor. This is what I was following.
Removal Procedure
1.Remove the left instrument panel insulator (this is the carpeted cardboard piece above the brake pedal that connects to the knee bolster)
2.Remove the knee bolster (this is the pad below the steering column)
3.Remove the steering column filler (this is the metal piece behind the knee bolter, under the steering colum) (4 larger bolts, and I think 2 smaller ones)
4.Disconnect the electrical connector from the temperature actuator.
5.Remove the HVAC Con (HVAC Control) MiniFuse #27 from the IP electrical center.
6.Remove the mounting bolts from the temperature actuator.
7.Remove the temperature actuator.
Old 07-28-2011, 12:25 PM
rkvons's Avatar
rkvons rkvons is offline
Is this the automatic dual zone climate control setup? If it is, it is the same as mine, and I was able to gain access to it by removing the bottom piece like you did already and then laying on my back on the floor and reaching up with my left hand. It was basically done by feel. It requires some patience.
Old 07-28-2011, 01:49 PM
It is automatic, so you think I should be ok without removing that metal plate? (steering column filler)
Thanks
Old 07-30-2011, 06:00 PM
well I finally removed it but the actuator seems to be working ok on both sides. but i'm still having the same issue, warm air on the driver's side and a little cooler on the passenger's side. Also the steps I was following mentioned removing the HVAC control fuse if I was going to remove the actuator, but when I checked there wasn't a fuse there. Any thoughts?
Thanks.
1998 grand prix GTP 3.8L V6 supercharged, random misfire gtpmaddi Grand Prix 2 04-19-2011 08:16 PM
98 Pontiac Grand Prix GTP Idler pulley pumcher Grand Prix 3 01-29-2004 01:08 AM
Pontiac Grand Prix GTP lil_schmitts Prelude 15 08-12-2003 12:12 AM
55" Pontiac Grand Prix GTP Twin Wing Spoiler Scott 02 Grand Prix 2 05-13-2003 06:09 PM
