Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-27-2011, 05:17 PM
debsco731 debsco731 is offline
? about 2.2 5SFE 97 Camry engine swap
My son has a 1997 Camry with a 2.2 5SFE engine. It spun a rod bearing and we are looking for a replacement engine. Is there any way to install a pre-1997 2.2 5SFE engine in the 97? We are finding it almost impossible to find the 97-01 2.2, but we have found quite a few older ones. Any help is greatly appreciated, thanks so much.
Old 07-27-2011, 05:36 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: ? about 2.2 5SFE 97 Camry engine swap
G'day,
You will find that all the 5sfe engines have the same block and head, but there may be some differences in things like sensors, accessory locations, etc, between the different model years.
You maybe able to buy a pre 97 block and head, then swap your current set of sensors and accessory's etc over.
But, I know as many people who managed this with Toyota engines with out any problems, as I know people who have had trouble doing it.
Have you thought of just replacing the bearing?
Or has it damaged the crank as well.
Old 07-27-2011, 07:21 PM
Yes, it took a chunk out of the crank, the oil pan was full of metal shards.
Old 07-27-2011, 10:46 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Given the choice, I would buy a block and use all the other parts from your existing engine, assuming you know the parts to be good. As small a change as moving a mounting hole makes life difficult.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-31-2011, 10:00 PM
The pre-97 has a distributor, not coils packs. Can you convert the pre-97 to coil packs and block the distributor hole?
Also, pre-97 has no camshaft positon sensor. Is there a place to put one on the pre-97? Thanks so much for your help.
Old 08-01-2011, 01:30 AM
Moppie's Avatar
Master Connector
The simple answer is no.
The more complex answer is yes, if your prepared to strip the pre-97 engine back to short block, and transfer and head and mounting brackets over from your later engine.
But, it would be easier to find a post 97 engine, or get a new crank and do all the big and small bearings.
Old 07-04-2012, 09:49 PM
jdmfinder86 jdmfinder86 is offline
Lightbulb Re: ? about 2.2 5SFE 97 Camry engine swap
I actually just done this myself works great. Only thing u have t do I swap intake manifolds all timing covers including one under the cam gear lower timing pulley cam gear and make a bracket for the cam positioning sensor to mount to....sounds like a lot but its easy as hell
Old 12-21-2012, 05:13 PM
boisemark boisemark is offline
jdmfinder86,
We bought a used Camry and it appears someone did just that... but the bracket they fastened to hold the camshaft position sensor wasn't done right, and there is either too big a gap, or it goes to far inside and hits the camshaft.. and the current camshaft position sensor is dented and no longer works.
So, I want to get the new one on right.. can you explain what you did for a bracket?
Do you have any photos or advice?
Thanks a million!
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
98 Camry engine replacement. posiman Camry/Camry Hybrid/Vista 6 02-01-2010 01:00 AM
no start 95 cavalier 2.2 jeffyweasel Cavalier Problem Diagnosis 2 03-14-2009 06:12 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
Nissan Quest V6 to 2.4 ltr 4 cylinder swap Scraped Knuckles Quest | Presage | Serena 4 02-20-2009 08:59 AM
