Old 07-27-2011, 05:08 PM
hidden1 hidden1 is offline
fuel psi reading
when checking the fuel pressure on 91 grand voyager what psi reading should i get before filter(new pump installed)..
Old 07-27-2011, 06:16 PM
Re: fuel psi reading
Oh yea its a 3.3, 6 cyl
Old 07-27-2011, 07:16 PM
tempfixit tempfixit is offline
3.3 engine 48psi, engine running, vacuum hose disconnected from fuel pressure regulator according to Haynes manual.
Old 07-27-2011, 08:57 PM
i checked it before filter----all the way to top/end! 100.(just engaging pump-no start).
-is this way too high?
will check at rail hook up tommorow
Old 07-28-2011, 10:25 PM
Got a better tester and rechecked pressure.It is 38 at port with regulator hooked up and 48 with regulator.Also checked it before and after filter..was 40-- but when regulator off it then went to 48.
Is this normal? i thought it was to be 45 with it hooked up?
Does it sound like regulator is problem? or weak pump?
2003 Silverado, fuel PSI regulator location? hoop22 Silverado 3 12-16-2006 09:48 AM
Help oil psi reading 0 1993GAGT Grand AM 4 04-06-2006 09:36 PM
Fuel Pressure reads 40 Psi Scaramanga Lumina 17 01-21-2006 06:37 PM
What should my fuel psi be? shadow-racer General Discussion 1 07-29-2005 07:40 AM
whats the best Fuel psi B16A first Gen Kakarrott '88 - '91 Civic | CRX | Wagon | Shuttlee 1 04-19-2003 08:11 PM
