Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 05-30-2003, 08:18 AM
Big_Ez Big_Ez is offline
Will fit?
I am intrested in getting some 20" 144 spoke player wire rims with Low Profile 255/35/20 tires.....will this fit on a 88 buick? if not will 18's?
Old 05-30-2003, 03:03 PM
Cy@tirerack Cy@tirerack is offline
What Buick do have? Is it stock ride height?
Old 05-31-2003, 01:49 AM
Sorry i meant 88 Buick Park Ave. and yes its stock height.
Old 05-31-2003, 01:13 PM
We haven't test fit a 20" tire on your car because running a 20" wheel on this car would require a tire that's too small to carry the load of the vehicle.
The largest tire we've test fit on the vehicle is a 235/55-16 which is 26.2" tall, so a 255/35-20 with an overall height of 27" would probably rub or hit the top of the wheel well unless modifications such as fender lip rolling, wheel well trimming, alignment changes etc are done.
If found some other Park Avenues on the web, some of which are running 20's so I would recommend checking with these owners to see what modifications would be necessary.
http://www.cardomain.com/member_page...=Park%20Avenue
Old 05-31-2003, 02:30 PM
Great thanks for the help man.....ill probably just throw 18's on it if its too much trouble to put 20s on....the 18's come with Low Profile 225/40/18 or 235/40/18 or 215/35/18...those will be fine right?
edit..well forget that the only FWD Player Wire Rims are 20".....would getting raising springs put on fix the problem?
It will fit...but will it hold plus another question Cain98Eclipse Off-Topic 10 01-26-2006 06:23 PM
w0t high power engine will fit in a mk 2 golf driver with least amout of efort to fit yale32 Golf 0 05-02-2004 03:36 PM
Does anyone know if 18x8's will fit??? slickkedar Cosmetics 2 07-19-2001 06:06 AM
what seats will fit? Project320i 3 Series 0 07-09-2001 01:34 PM
