Old 01-25-2006, 09:45 PM
Cain98Eclipse Cain98Eclipse is offline
Send a message via AIM to Cain98Eclipse Send a message via MSN to Cain98Eclipse Send a message via Yahoo to Cain98Eclipse
Question It will fit...but will it hold plus another question
I have a CAI (not installed) but its rains a hell of alot here and I have to go through puddles upto 4-5 inches deep. So I was thinking of just using the top part in the rainy season......but will using just these clamps ..hold it on because on this piece of the pipe there is not place to bolt it down, like on the bigger piece there is. Also when I am driving from 1st to 2nd to 3rd I have a light grinding noise mostly going up hills but sometimes on flat road. What could this be my tran, clutch, or just something i might be doing? Would really like to hear almost everyones
Old 01-25-2006, 09:50 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: It will fit...but will it hold plus another question
I have no fucking clue what you just asked, you should rephrase and re-ask the question.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-25-2006, 10:22 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
If you're asking if the band clamp will hold then of course it will, is that what you asked?
now - 2000 civic
soon - 2002 is300
Old 01-25-2006, 10:36 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
DSM geek
Old 01-25-2006, 10:51 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
I 2nd that...wtf did you just ask?
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 01-26-2006, 07:26 AM
I was asking if the band clamps would hold it on but that was answered ^ and when I am driving when I shift from 1st to 2nd and from 2nd to 3rd I have a light grinding noise mostly going up hills but sometimes on flat road. It makes the noise while I am in the gear not going to the gear. What could this be my tran, clutch, or just something i might be doing?
Old 01-26-2006, 10:55 AM
SLoe's Avatar
SLoe SLoe is offline
Originally Posted by Cain98Eclipse
I was asking if the band clamps would hold it on, but that was answered.
When I am driving, I have a light grinding noise mostly going up hills, and sometimes on flat road. It makes the noise while I am in the gear, not going to the gear. Could this be my tran, clutch, or just something i might be doing?
I fixed your question. Now maybe you can get a better answer. Punctuation is your friend. So is www.vfaq.com . Go now. READ, and come back a more enlightened DSMer.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 01-26-2006, 11:45 AM
It sounds like a tranny going bad if it grinds while in gear. This happens even when the car is fully warmed up? Try changing the tranny fluid, BG Syncroshift II ftw.
EDIT: I'm not sure about the non-turbo's, I have no idea what you can and can't use. make sure you check before you change it!
now - 2000 civic
soon - 2002 is300
Old 01-26-2006, 12:39 PM
Originally Posted by crunchymilk55
It sounds like a tranny going bad if it grinds while in gear. This happens even when the car is fully warmed up? Try changing the tranny fluid, BG Syncroshift II ftw!
Thanks I will try that and see if that works.
Old 01-26-2006, 04:48 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Judging by the picture it looks like its going on a n/t. If you are going to change the tranny fluid, you can only use factory tranny oil. It has to say NV-T350 on the bottle. Otherwise you will screw up your tranny.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-26-2006, 06:23 PM
Nayr747's Avatar
Nayr747 Nayr747 is offline
In the original post, I think he was asking if the band clamp alone would hold the intake pipe on without the hanger. I would say it would depend on the angle, weight, etc. Tighten it down good and try and move it around. If it budges then I'd gheto rig a hanger. You can bend a piece of metal and stick one end under the band clamp around the filter before you tighten it, and the other end somewhere secure. Allow enough play for the engine to move when it revs though.
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
