Go Back   Automotive Forums Car Chat > Buick > Regal
Old 07-25-2011, 07:35 PM
MinnesotaDrive85 MinnesotaDrive85 is offline
Bad MAF related to o2 sensor??
The MAF sensor recently went bad on my 2000 supercharged Regal, could this be related to the o2 sensor that was replaced a couple of months ago?? Since owning this car (for only 6mo now) I have never had good fuel economy, bought it with an o2 sensor needing to be replaced, was replaced by a friend, not a certificed mechanic, and it did not seem to make a difference in fuel economy. Now the MAF has gone bad, is this just bad luck or is there a chance the o2 sensor was not correctly replaced? Only code I am getting is for the MAF. After this friend of mine did my brakes, the right front ABS sensor went out, so I am beginning think he did a total hack job on my car!!!
Old 07-25-2011, 09:20 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Bad MAF related to o2 sensor??
There is no relationship between the MAF & the 02 sensor. They operate totally independent from each other. In addition, the brake pad/rotor replacement, should normally have nothing to do with an ABS code. You need to have the ABS system scanned to see what the code is. BTW, how many miles on this car?
Old 07-26-2011, 01:06 AM
160k miles. The ABS light came on immediately after brakes and wheel bearings were replaced...thoughts? Good to know that MAF is not related to the o2 sensor, thank you. Since I've read that the remanufanctured MAF units often fail, especially Cardone brand, I'm getting one from salvage today instead. Any thoughts/advice?
Old 07-26-2011, 07:39 AM
danielsatur danielsatur is offline
Look for a spare wheel speed sensor too!
80% of the braking is put on the front brakes, check and clean the wss.
Old 07-26-2011, 09:58 AM
GTP Dad GTP Dad is offline
Pontiac Guy
The brakes have nothing to do with the wheel sensor. If you replaced the bearing then the wheel sensor is part of the assembly. It is possible that the sensor was not corrected properly or that the sensor you put in was bad. I also suggest that you be very careful with a used MAF sensor. You may get a good one but the chance of getting a bad one is also a possibility.
I don't think your friend has anything to do with the issues you discussed just some coincidences.
Old 07-26-2011, 02:22 PM
Replaced MAF sensor with a salvaged one today, car is still acting like it was yesterday with the bad sensor unplugged (RPM jumps when idling, between 500-1000). Service engine light still on (from being unplugged overnight?) Will resetting the computer solve this?
Old 07-26-2011, 02:26 PM
Yes - Reset the computer
Old 07-26-2011, 03:09 PM
Success! Thanks to all. Fingers crossed this one holds out!
MAF sensor or ported throttle body DrRadar Grand Prix 7 04-21-2010 08:40 PM
2009 Matrix S 2.4L IAT Sensor Johnnies2000 Corolla/Matrix/Voltz 2 11-24-2009 02:30 PM
P0102- Bad MAF?!?! Dekeman Windstar 5 03-16-2008 02:34 PM
is this a bad MAF ? NiSmO_zt 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 12-30-2004 04:23 PM
Bad MAF? Arnoldtheskier Escort 4 08-01-2004 03:42 PM
