Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-25-2011, 05:24 PM
STurgisSTeele STurgisSTeele is offline
Question chirp sometimes works
When the car is locked/unlocked, the chirp sometimes works and other times doesn't. And even once in a while it sort of squeaks. Any thoughts? Maybe replace the little chirping device?
Thanks!
P.S. it's a 1998 with 5S-FE engine, if it matters.
STurgisSTeele
Old 07-25-2011, 09:04 PM
Re: chirp sometimes works
update:
just noticed that the lights, when flashing, correspond somewhat to the sound/no sound of the chirp. I noticed that the lights flashed very dimmly the same time the chirp was not working.
So, is there a relay or something not providing the needed power to the lights and the chirp device when locking/unlocking the car?
Thanks!
STurgisSTeele
Old 07-28-2011, 05:11 PM
another update. As of lately, the chirp hasn't worked but the lights are full brightness. Hmmm.... any ideas. Seems to me it just might be the chirping device. I'll continue to look into this.
STurgisSTeele
Old 07-28-2011, 06:12 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Thank you for the updates. I don't understand chirpers...
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-30-2011, 06:15 PM
Maybe call it a confirmation note, or beep, but when the doors are locked and unlocked using the remote key fob it chirps.
For the last two days, the lights flash fine, but no beep, or chirp, for a confirmation occuring.
I've tried looking for this part at online part stores, but having trouble locating due to not knowing the proper name for this thing. It's located under the hood near the top right corner area. It is strapped to some existing wiring and wrapped in a foam-like piece. If I can find an engine compartment diagram, I may be able to identify it.
STurgisSTeele
Old 07-31-2011, 01:39 PM
Brian R.'s Avatar
Resident Chemist
A Toyota parts department will have a parts breakdown.
Old 08-09-2011, 11:52 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
It is possible that the grounding wire for the "chirper" or alarm horn has become corroded and isn't making good contact with the body. You can take a screwdriver to remove the screw that attaches it and clean the connector and screw with a scotch-brite pad, then reattach it.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
92 f350 diesel StArTer issues! sometimes works sometimes doesnt brattzzzzz F Series 4 04-24-2006 09:13 AM
95 SE 3.1 daytime running lights sometimes work? oneblade Grand Prix 0 04-06-2006 12:26 PM
95 STS Blower motor-Sometimes works j4hennig Seville 2 10-15-2005 08:56 PM
94 camry rear speakers sometime work ? tarunkapoor1 Camry/Camry Hybrid/Vista 0 04-04-2005 02:42 PM
Odo- sometimes working/also for sale? Cheryl84944 924/944/968 1 08-20-2003 10:42 PM
