Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 07-25-2011, 12:10 AM
DXJ DXJ is offline
82 Celica choke voltage
Does anyone know why the voltage at the choke bi-metallic coil is 17.2v? The voltage is nominal everywhere else. I have installed a Weber carb, and now I'm chasing down some electrical problems related to an intermittent won't crank problem. Any insight would be appreciated.
I found the answer to my own question. After some repair to the wiring harness, voltage at the choke decreased to 15.7v. The wire to the choke goes indirectly a special connection on the alternator, and seems to be the same as the alternator field voltage. Toyota designed it this way.
92 Lumina Won't Start ICM Voltage Brndo Lumina 9 05-02-2010 11:37 PM
is it weird my oxygen sensots voltage changes WHEN THEY'RE UNPLUGGED? bac512 Savana 0 07-29-2009 10:20 PM
86 IROC Carb V8 - Choke Light / Choke stays on OET F-Body Problem Diagnosis 4 05-21-2007 07:19 PM
Celica 101's celica (WIP) nicecar Sketching and Drawing 7 10-25-2005 06:13 PM
¿ Hyper Voltage System - Voltage Stabilizer ? johnnybate Celica 8 09-26-2005 08:56 AM
Tags
22r , choke , voltage
