Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 07-24-2011, 03:54 PM
IMtnBike IMtnBike is offline
Unhappy back up light problem 2004 Express
I was trying to add a back up warning device today. The instructions said to attach one wire to the positive wire going into the back up light and ground the other. The wires coming out of the light socket is black & green. I tried every combination possible and could'nt get it to work. Now, my back up lights don't work at all. I checked the fuses and they are good. Any suggestions? By the way, the back up device does work.
Jeff
Old 07-24-2011, 06:34 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: back up light problem 2004 Express
Jeff
As in back up light device works is that hooked up to back up circuit and in reverse position on shift lever?
Where did you tap into backup lights?
Does it still have 12 volts to backup lights?
IF NOT YOU ARE LOSING VOLTAGE SOME PLACE.
Trace wiring back and see where you are losing it.
MT
Old 07-24-2011, 06:35 PM
MT-2500's Avatar
AF - Advisor
Jeff
Does back up lights work with backup devise unpluged?
MT
Old 07-24-2011, 09:19 PM
Thanks for the reply. I should have said that I checked out the warning device by attaching it to a battery. Nothing is attached to the back up light wiring now.
Jeff
Old 07-25-2011, 05:32 AM
MT-2500's Avatar
AF - Advisor
Jeff
Sounds like you need to fix your backup light circuit.
For help.
Go to post 2 and answer questions.
MT
Dash Lights & Battery Light LilBitEG Explorer | Explorer Sport Trac 2 09-10-2010 06:47 AM
Need to remove backseat side back rests on 2004 I35 tgneid Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 09-21-2009 05:15 PM
Brake lights problem corollastudent Corolla/Matrix/Voltz 1 07-20-2009 12:39 PM
Trunk light problem sudaloo Sephia 0 06-12-2009 10:42 AM
Daytime running light problem? 2004 Sorento LX 4x4 Jason_S Sorento 0 08-30-2006 07:20 PM
