View Poll Results: Sea Foam
Recommended Product 6 75.00%
It's all Hype 1 12.50%
Don't even think about it 1 12.50%
Stick with STP Products. 0 0%
Voters: 8. You may not vote on this poll
Old 07-24-2011, 12:29 PM
knightjp's Avatar
knightjp knightjp is offline
Sea Foam
Engine cleaning on the outside is great. What about the inside???
I've heard of STP for cleaning fuel systems and injectors, but recently I came across this....
Sea Foam - http://www.youtube.com/watch?v=DjXVi...layer_embedded
There are a number of videos on youtube about doing it.
http://www.youtube.com/watch?v=vRAV5...eature=related
http://www.youtube.com/watch?v=zt_oX...1&feature=fvwp
Has anyone ever heard or used this????
Enjoying the Alfa experience.....
Old 07-27-2011, 09:00 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Sea Foam
Ive used it on several cars of mine and my friends. If done right it can really help.
Old 07-27-2011, 09:52 AM
danielsatur danielsatur is offline
Re: Sea Foam
Distilled water works good for decarbonization, see
www.automotiveforums.com/vbulletin/showthread.php?t=283211
A bad head gasket, the cleanest part of engine is on the cylinder were the gasket went bad.
Old school mechanics used transmission fluid through the vacuum hose todo decarbonization.
Old 07-27-2011, 01:04 PM
vgames33 vgames33 is offline
Re: Sea Foam
Seafoam does work. A shop I used to work for used it as a first step for boarderline emissions test failures. The before and after results showed a noticable decrease in NOx emissions on most cars, and they often ran a little smoother after we were done. I'd recommend it as a maintenance thing every once in a while or on a new-to-you vehicle. Just make sure to do it outside, as the fumes are pretty harsh.
Old 07-27-2011, 04:11 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Sea Foam
It's a not a product I've ever seen outside of North America, but I hear lots of people here talking about it.
Just what is Seafoam?
Old 07-27-2011, 08:35 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Sea Foam
I've used SeaFoam for cylinder decarbonization several times and am very impressed with it. Recently I had the, umm, pleasure, or pulling the head off of an engine that had recently been decarboned with SeaFoam and was impressed with how clean the valves were. For what it's worth, the SeaFoam treatment was performed to see if it would improve a misfire that ended up being a bad valve.
I've also been warned that, while water will work, you need to be very careful not to spray in too much as it can burn valves.
I've not tried SeaFoam for any other applications such as with the oil or mixed with the fuel, only poured in through vacuum hoses.
-Rod
Old 07-27-2011, 10:38 PM
Re: Sea Foam
http://www.seafoamsales.com/
Old 07-28-2011, 02:44 AM
knightjp's Avatar
Re: Sea Foam
-Rod
Don't tell me that the Taurus in your avatar is having a bad valve.... Looks like a brand new vehicle.
Old 07-28-2011, 07:53 AM
shorod's Avatar
SHO No Mo
Re: Sea Foam
Nope, I've had no problems with the SHO in my avatar. The vehicle that had the bad valve was my mom's 2003 Dodge Grand Caravan.
-Rod
Old 08-28-2011, 06:40 PM
Intuit Intuit is offline
Re: Sea Foam
Running solvents through an engine's fuel system is one thing. Running them through an engine or transmission's lubrication system is another.
Not professing to be an expert but running non-lubricants is a bad idea and severely cuts into the service life.
Although slower and more expensive, the best way to clean an engine/transmission is to do hyper-frequent filter and fluid changes; and keep it tuned up. Avoid mal-maintained fuel stations that haven't changed their tanks and/or fueling equipment in 15 years.
I've used injector cleaner with most oil changes, STP Complete Fuel System Cleaner at least once every year or two, and have changed my Castrol brand oil frequently. My engine has always been very clean and expect it to be no different now at >260k, than it was at ~190k.
Contaminants also enter via air filters, vacuum leaks and EGR systems.
Old 08-29-2011, 09:37 PM
Kind of a Big Deal
Re: Sea Foam
FWIW I dont put the stuff in my oil. in my gas tank and use the rest for upper engine cleaning
Old 08-30-2011, 02:36 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Sea Foam
Unless you have significant build-up of sludge or oil-staining inside the cam covers, there probably is no need to add Sea Foam to the oil. If you do add it, it is recommended to add it a few hundred miles before the scheduled oil change. It is petroleum based naptha, a light oil, which can thin the viscosity out a bit but not enough to cause wear problems...we're talking a pint versus ~5 quarts.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 09-02-2011, 11:23 AM
Johnnyx1257 Johnnyx1257 is offline
Re: Sea Foam
We used it in my friends 2004 Audi a4. It smoked a lot lol. couldn't really feel a difference after we were done
http://twitter.com/johnnyx1257
Old 09-02-2011, 01:13 PM
jdmccright's Avatar
The RustBuster
Re: Sea Foam
It's supposed to smoke alot...says so right on the can. You may not feel a difference, but your engine will thank you.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 09-20-2011, 12:36 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Sea Foam
The only thing I will run Seafoam through is the intake. I use Redline fuel system cleaner. And as for pouring it in you crank case. Well, I would drive the car. I use Gunk Motor Flush or one quart of ATF. I pour it in right before I'm going to change the oil. Just let it idle for 10 to 15 minutes. Drain and change the oil and filter.
DO NOT drive or rev the engine putting ANY of these products in your oil. You run the risk of spinning a bearing.
Sea foam? Classicrocjunkie Cavalier 4 02-01-2005 12:40 AM
Sea Foam Motor Treatment 86bowtie Caprice 15 12-19-2004 07:49 PM
sea foam OLew3 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 8 08-02-2004 12:17 PM
Sea Foam?! amitykamity '88 - '91 Civic | CRX | Wagon | Shuttlee 7 07-11-2004 12:36 AM
sea foam tidalcock C/K 1 06-20-2004 04:30 PM
