Old 01-31-2005, 11:01 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Sea foam?
Anyone here use it and what are the side affects?
- Where do you add it to? I've heard a few different places...
- How is it on Gaskets? Valve and head..
- Do you have to change the oil right after it?
- Is there one sold by the dealership or just one brand?
- A step by step guide would help alot and anything to watch out for. I think i am going to do this tomorrow on my day off if all goes well...
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 02-01-2005, 12:23 AM
noshun's Avatar
noshun noshun is offline
Re: Sea foam?
With engine warm, slowly pour 1/3 to 1/2 pint through carburetor or throttle body throat. (If vehicle is port injected slowly pour SEA FOAM through direct manifold vacuum line that will feed all cylinders, possible sources are P.C.V. valve or brake booster line.) This will pull SEA FOAM down on top of the pistons and to the back of the intake valves to dissolve carbon. Turn ignition off. Restart engine after 5 minutes. If severe carbon build up is apparent, use more Sea Foam as previously directed. Make sure exhaust is well ventilated when using Sea Foam in these various ways as fumes will be extreme for a short time.
Pour 1/3 to 1/2 pint into oil crank case to clean rings, lifters, dirty parts and remove moisture.
Pour 1/3 to 1 full pint into fuel tank to clean injectors, carburetor jets, fuel lines and remove moisture.
Immediate Results: Smoother idle, increased R.P.M.'s better throttle response and improved performance. See label on can for detailed results for use in each area.
There's how.
Right I use Wynn's Engine Tune Up which is exactly the same it shouldn't damage anything in your motor! It's made from just pure gasoline so wont do any damge!
Is that good enough?
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 02-01-2005, 12:29 AM
Lifted GMT-360!
Re: Sea foam?
Is that in your own words?
Old 02-01-2005, 12:31 AM
noshun's Avatar
Re: Re: Sea foam?
Well it weren't in yours. It's basically what the proper instructions are just how I copied and pasted them!
Old 02-01-2005, 12:40 AM
Lifted GMT-360!
Re: Sea foam?
lol... i just stumbled across their site finally and was like....hmmm.... word for word... lets see if we can play mind games. But thou are smarter than i thought.... good man... I'm outty for the night...
