Go Back   Automotive Forums Car Chat > Mercury > Marauder
Old 07-23-2011, 09:29 PM
cam 540 cam 540 is offline
2004 Mercury Marauder PO191 code
My Marauder started idleing rough today and hasn't been driven in about a month and then it died and now won't restart it just turns over i checked the coded with my code scanner and it comes up with a PO191 fuel pressure senser fault has anyone had this problem and what did you do to fix it? My car only have 12000 miles on it and does alot of sitting any help would be apprciated
Old 11-08-2012, 11:21 AM
buckiejr buckiejr is offline
Re: 2004 Mercury Marauder PO191 code
Went to the dollor store the other day came out started the 2004 mercury sable it started but died then it would not do anything thing not even turn over waited 30sec it stated up.
Old 05-09-2015, 02:26 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Yes, this is an old thread but it might help someone with this problem in the future, so:
1. The P0191 is usually a faulty fuel pump.
2. Don't run your car out of gas!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
2004 Mercury Marauder niterider330 Marauder 3 08-23-2007 07:12 PM
2004 mercury montery vibration JACK106 Crown Victoria 4 07-16-2006 07:34 PM
Mercury Marauder 423REED Marauder 2 06-15-2004 08:37 PM
04 Mercury Marauder vs 97 GTP Coupe MoshimoGTP Grand Prix 9 03-29-2004 06:50 PM
Mercury Marauder DVSNCYNIKL Grand Marquis 6 07-20-2003 05:59 PM
