Stereo Help!
I've installed roughly 12ish stereos before into various vehicles, needless to say I'm not exactly a beginner... but when I went to install an aftermarket stereo into my SL1 I found something kind of weird...
The stock stereo had an adapter on it already and it was a Single DIN stereo. Nevertheless I had already bought a wiring harness and I used that for the stereo, got it all wired up, 100% correctly, double triple checked, and now when I put the car in the start position to check and see if it works it won't power on... I can hit the eject button and it lights up and ejects... and if I hit the display button then it will light up and show the time for about 10seconds then go back off.... The stock stereo had a grounding wire that was hooked up to the chassis and I've tried using it and just using the ground from the harness, doesn't work either way... The stereo came out of another vehicle and was working fine when I took it out. Its a 2002 Saturn SL1 and I'm trying to install a JVC KD-HDR60 Heres a link for the new stereo: http://support.jvc.com/consumer/prod...3&archive=true and this is the stock stereo: http://www.dhgate.com/2002-sl1-satur...f2fee1d89.html |
Re: Stereo Help!
The aftermarket wiring harnesses for these cars are meant for use with Saturn S-Series (2000-2002), L-Series (2000-2005), Vue (2002-2003), and Ion (2003 only). For the most part the wiring is the same between these models EXCEPT for the aforementioned accessory/ignition lead. For your 2002 SL1, the switched ignition/accessory lead from the radio needs to be hooked up the the wire going to the A6 position on the plug (it's A4 for SW/Vue, A6 for SC/SL/Ion, or B2 for L-Series).
My rides: 2007 Chevy Equinox LT FWD 2018 Chrysler Pacifica Touring L "If women don't find you handsome, they should at least find you handy!" - Steve Smith (Red) Last edited by Ruley73; 07-25-2011 at 01:45 AM. |
| The Following User Says Thank You to Ruley73 For This Useful Post: | ||
Derk_eliso (07-25-2011)
Re: Stereo Help!
Yeah, my buddy came out last night to help me and that's what we found out. We touched the red and yellow together and it came on, so we determined the red wasn't getting power and that was the ignition/acc. So we used a voltmeter to find the live wire from behind the harness and just spliced off that wire. Had nothing to do with the ground/chassis.
But yeah, problem solved... for any future people who search for this, that was the problem. And thanks again for your valueless input! |
