Old 07-23-2011, 11:50 AM
lesabrefan lesabrefan is offline
Replacing ball joint
Hello, attempting to replace a ball joint on 96 Lumina. I'm following instructions from here: http://www.gpona.com/forums/a-remind...nts-t6246.html . All is done up to the point where the instructions say: "Remove ball joint nut and pin and pry the strut assembly away from the control arm once done remove the 3 bolts that mount the strut assembly to the unibody". I've removed the nut and pin and 3 bolts on top, how in the world do I remove the whole assembly. I can't do it from the bottom as the bolt that's in the control arm is being pressed down by the spring and obviously I can't remove it from the top, since the spring is pushing up on it.
There has to be something that I'm missing.
Thanks a lot in advance.
1996 Lumina 3.1 - 191K
2001 LeSabre Custom - 153K
2006 Explorer 4.0 - 55K
Old 07-24-2011, 09:29 AM
maxwedge maxwedge is offline
A990 racer
Re: Replacing ball joint
Try this link. http://www.autozone.com/autozone/rep...00c15280068256
?? Difficulty Level of Replacing Ball Joint? '95 Transport yellowfiero Trans Sport 5 07-20-2005 11:48 AM
99 Ranger replace ball joints ARBAT Ranger | Courier 0 02-01-2005 08:38 AM
Replacing Ball joints 98 2WD danh0ward S-10 5 09-30-2004 11:10 PM
Replacement Ball Joint torque specs for the 3 bolts to the control arm. Slade901 Grand AM 2 05-05-2004 01:23 PM
anybody got how to's on replacing ball joints? mellowboy '88 - '91 Civic | CRX | Wagon | Shuttlee 20 01-22-2003 10:46 AM
