Old 07-22-2011, 10:26 PM
Tom63 Tom63 is offline
98 cavalier overheating
I have an overheating problem.I have changed the thermostat,checked anti-freeze for oil mix thinking maybe headgasket,no oil in anti-freeze,fan is working,can it be the water pump.Is there a way to check the water pump.Also i checked the hoses ,the lower hose is ok(when car is running hose is cool),the upper hose is worn a bit(it is very hot when car is running).
Old 07-23-2011, 07:55 AM
MikeS144 MikeS144 is offline
Re: 98 cavalier overheating
see if you have heat. If your water pump is not working it will not circulate hot water through the heater core. are you losing water?
94 Safari 203000 miles
94 metro 310000 miles
The Following User Says Thank You to MikeS144 For This Useful Post:
Tom63 (07-25-2011)
1993 chevy cavalier OVERHEATING benfu Cavalier 9 07-28-2005 10:44 PM
96' Cavalier Overheating mitchmoney Cavalier 3 03-27-2005 10:28 PM
'97 Cavalier, overheating MamatoShelbyLou Cavalier 4 02-23-2005 08:00 AM
99 Cavalier overheating alwager Cavalier 0 09-20-2004 08:35 PM
