Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 07-21-2011, 02:13 PM
comet240 comet240 is offline
00 sunfire replace strut bearings?
hi i have a 2000 sunfire i went to certify it and they told my sister i need new struts but i guessing the bearings cuz it make noises when u turn but i didnt think the bearing were part of the safety
either way how do i do that job?
Old 07-22-2011, 06:44 PM
82Stang 82Stang is offline
Re: 00 sunfire replace strut bearings?
Anything in the suspension that is bent, broken or maladjusted, can be failed for state inspection. And unless you have a spring compressor, you won't be able to change the strut mount. The whole strut assembly can be removed from the vehicle without too much trouble and then brought to a repair shop where they can compress the spring and replace the strut mount.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 08-08-2011, 07:30 PM
Tech II Tech II is offline
These bearings/mounts are REAL noisy in cold weather....soon as summer comes, things expand and the noise goes away....when you look at the bearing, you almost laugh, or in some cases cry.....
Old 08-11-2011, 07:29 AM
ya i crying right now i cant get the top nut off wont come loose sure the bearing turns and on this car its bad in summer when u turn it makes a banging sound lol
i got the replacement one ya i crying cuz just 2 plastic parts put together lol
so how do i get it it loose
so i got the spring compressors on too so what are the steps i hope the whole thing doesnt have to come out?
Old 08-16-2011, 04:50 PM
ok so i have replaced both sides and a strut but i got a problem i never remembered where the spring sat so i looked on my other sunfire and cav tried those positions then it didnt work turned sprinng more but still doesnt work if i press on the fender bouncing on the car the spring compresss but hte shaft comes up a bit so there is play but i cant tighten anymore as the shaft spins is there a specal tool that holds the bolt and that u can twist the shaft tighter? to the nut?
Old 08-22-2011, 04:57 PM
so does anyone know if there is a special tool to tighte the top nut for the strut after replacing the bearig since there is still play in it
Old 02-20-2012, 04:47 PM
e40water12 e40water12 is offline
Doesn't sound like a suspension bearing, Sounds more like a strut mount it self. It gets old the rubber shrinks in size. and causes the mount to make noise. Common issue with these cars. Ive changed mine 2 times on my 01 cavalier.
Old 02-21-2012, 12:16 PM
rkvons's Avatar
rkvons rkvons is offline
You have the springs compressed, get the nut started on the end as far as you can before the shaft starts to turn on you, then you release the spring compressors to put force on the nut, and finally use an impact to turn the nut. That's how I do it. Sometimes you can put a wrench on the top of the shaft to hold it while you turn the nut. I've done that too.
Old 02-23-2012, 08:03 PM
Yes I agree with the last post. If you got an impact wrench or air Ratchet with the coil spring slightly compressed with the Anchor's. I top nut will undo nicely.
2000 Grand Prix Strut Replacement mikepieronek Grand Prix 8 05-05-2010 08:40 PM
2001 Sunfire Sqeak or Rattle from Front Strut Bearing Mount herbsch General Discussions 4 01-04-2006 06:11 PM
Need Instructions on how to replace a strut bearing!!! Help Bird_Dog Jetta/Vento/Bora 1 09-09-2004 12:21 PM
Replacing Strut Bearings On Achieva S CAR LEARNER Tires and Wheels 1 07-07-2004 01:04 PM
replacing strut bearing??? dmorlow Aurora 1 02-29-2004 03:07 AM
