Old 07-18-2011, 09:46 PM
jaygio31 jaygio31 is offline
gauge needle problem please help
The past 4 days on 2 occassions when just turning key to allow dash lights to display all my needles (fuel, rpm, speed, temp) went side to side for a couple minutes then reset to normal. i have a 2000 windstar. battery and alternator are about 2 1/2 years old. no dimming of lights when vent is put on high, has not died or needed a jump recently. any idea if anything else would cause this besides battery or altenator. probably started car and drove 12-15 times and only happened twice.
Old 07-19-2011, 08:47 PM
wiswind wiswind is offline
Re: gauge needle problem please help
It is possible that the voltage supply to the instrument cluster is varying.
This could be a connection issue......wiggle & reseat connectors......or a issue with a voltage regulator on the instrument cluster.....
I would expect a connection issue first.......oxidation on a pin in a connector can do this....and a simple unplug & plug back in is often all that is needed to solve the issue.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 07-19-2011, 11:04 PM
grog11 grog11 is offline
There are also the ground terminal wires attached behind the front driver plastic, internal left hand side fender wall. The ground screws being loose have caused this issue also. You may want to clean them and check tightness.
temp gauge and more...please help martini25 Cavalier 1 11-27-2007 01:41 PM
NO BUS message on dash gauge, dead gauge PLEASE HELP! blacksunshine Cherokee 6 08-06-2006 02:10 PM
Gauge Cluster Wiring, Please Help! DJ_Inevitable '88 - '91 Civic | CRX | Wagon | Shuttlee 3 10-05-2004 11:32 PM
gauges not working....please help kittles Cherokee 1 03-08-2004 11:37 AM
