Go Back   Automotive Forums Car Chat > Buick > Regal
Old 07-17-2011, 06:11 PM
sammi_rae87 sammi_rae87 is offline
Send a message via AIM to sammi_rae87
Cool 98 Buick Regal no start
I have a 98 Buick Regal which I just replaced the battery in, however it still won't start. All the lights and such work, however it won't crank or anything. The connections to the battery are all good. When I turn the key over I don't hear the starter engaging either. It's for sure getting fuel too. I believe it needs a new starter because it hasn't been replaced, but I'm just wondering if anybody else has had this problem and other view points. Thanks!!
Old 07-18-2011, 10:15 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 98 Buick Regal no start
Welcome to AF!!
There are two possible issues here. First the ignition switch is not making proper contact when you attempt to engage the starter. If you can get under the car and reach the back of the starter use a screwdriver to jump across the terminals. If the starter turns then the problem is with the ignition switch. If not the starter or solenoid is bad and will need replaced.
Old 08-27-2011, 06:18 PM
SuperFudd SuperFudd is offline
Do you hear the starter solenoid click?
Is this a problem that rarely hapened at first but got more frequent?
That was my situation with my 3.8L '96 Regal. Oil had been leaking on to the starter comentator and, over time, got burnt causing poorer and poorer connection. I had the starter replaced.
Old 08-28-2011, 08:49 AM
Tech II Tech II is offline
"I have a 98 Buick Regal which I just replaced the battery in, however it still won't start. "
Did you replace the battery, because it wasn't starting, or did this just happen after you replaced the battery?
Once again, look at the SECURITY light in the dash....turn key to on, don't crank....should come on for 3-5 seconds and then go out....
Does it stay on? If it does, then you have a problem with your theft deterrant system....does your ignition key have a black resistor pellet on it, or is it stamped PK3?
If the light does go out, then you need to attach a test light to the purple wire going to the starter solenoid....with the key in the crank position, the test light should light....it should be the same brightness at when you put the light across your battery terminals.....
If it is, then you have a bad starter.....can try giving the starter housing a love tap with a hammer as someone tried to crank it.....be very careful of ALL moving parts when you do this....
If the test light doesn't light, try starting in neutral.....still nothing? Then you need a wiring diagram to work your way backwards in the circuit to find the component failing, like the P/N switch, starter enable relay, ignition switch(this is to be checked if that SECURITY light went out after 5 seconds)....
transmission issues. 91 buick regal 3.8 bac512 Regal 0 04-25-2009 11:58 AM
93 Buick Regal Starting Problems Ed Hunter Regal 4 07-20-2006 09:07 PM
91 buick regal starting problems willystyles Regal 1 07-07-2006 04:23 PM
1988 buick regal starting problem Scott4545 Regal 4 01-11-2006 10:33 PM
99 buick regal starting problems csnba Regal 1 04-24-2005 02:20 PM
