Old 07-17-2011, 09:29 AM
CCascioli CCascioli is offline
2005 hyundai sonata timing belt
I have a 2005 hyundai sonata gls v6 with 168,000 miles. It has not run since i bought it so i took the timing belt cover off and found out the timing belt is broken. i was wondering what kind of motor this is and if the valves will be bent or if i could just replace the belt. I basically want to know if this is worth having fixed or just getting rid of it, and a ballpark price maybe. thank you
Old 07-17-2011, 10:16 AM
danielsatur danielsatur is offline
Re: 2005 hyundai sonata timing belt
1) Pull all the plugs + turn engine over by hand!
If noise or locked up, it's an interfearence type engine, and the valves are bent.
If ''ok'', put cylinder 1 on TDC.
2) Set all the timing marks + put a new timing belt on.
3) Check the compression on each cylinder.
Also see http://www.alldata.com
The Following User Says Thank You to danielsatur For This Useful Post:
CCascioli (07-18-2011)
Old 07-17-2011, 10:59 AM
Honestly I don't know how to get the back 3 spark plugs out
Old 07-18-2011, 09:53 AM
It looks like the Intake manifold needs to come off to get to the rear plugs, also
Yes - you have a interference type engine.
How much did you pay for her?
Old 07-18-2011, 01:44 PM
well if we have determined this is an interference type motor then we pretty much established the valves are most likely bent and its not worth fixing.. right?
Old 07-18-2011, 03:50 PM
It depends on how much you paid for her + DIY project.
Check KBB + NADA for value 1st.
You might just have bent valves on one bank, so you might only need to fix one head.
If you have a 2005 Hyundai Sonata, do you have water in your trunk trunkwater Sonata 6 09-13-2013 03:21 PM
05 Sonata Timing Belt dksob81 Sonata 1 03-07-2010 02:07 AM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
01 Sonata timing belt install chrisxb Sonata 7 12-19-2004 08:48 PM
2005 4 cylinders timing belt tdi Caravan | Voyager 1 09-09-2004 05:28 AM
Tags
belt , gls , hyundai , sonata , timing
