Go Back   Automotive Forums Car Chat > Oldsmobile > Oldsmobile Classics
Old 07-16-2011, 06:03 PM
cutlasscrazy cutlasscrazy is offline
Trying to save my 98 cutlass
I am almost at my end with this car...but i am willing to invest a bit more if it means getting this car running....so i have a 98 Cutlass V-6 and the original engine died at about 155K think i threw a rod or broke a piston thing clank n clunk so bad.
So i put a new-used 99 engine in it and it had all the same problems that the old engine had...so i fixed everything that was wrong on the old engine. So the only problem i have is this Tapping on the passenger side of the engine. it does while idle and when driving..
So the question is what could be causing this tapping are these engine known for having this problem. i have had two engines and both have this tapping problem. I am thinking it could be the Push Rods, lifters or the rocker arms but i want to know if there are any test i can do to narrow it down....PLEASE HELP
l
Old 07-16-2011, 11:38 PM
procaddytech procaddytech is offline
Re: Trying to save my 98 cutlass
A quick and easy test is to run the engine with the accessory drive belt off to eliminate a noisey accessory, i.e. a belt tensioner or a/c compressor esp. if they were swapped to the replacement engine.
Old 07-18-2011, 05:35 PM
I know that's not the case B/C i took all that stuff off the old engine...and it was new stuff every pulley and the belt... the knocking is def. inside the engine.
Draft cars and trucks save fuel serge_saati Cars in General 0 07-16-2010 10:32 PM
96 Cutlass Supreme w/ Rough Idle, but drives good chrisluna Cutlass Series 1 09-17-2009 07:29 AM
96 olds cutlass 3.1 fan relay AK47 SRH420 Cutlass Series 1 04-16-2009 09:33 PM
J-2 Rochester Tri-Power Ragtop_Renegade Oldsmobile Classics 2 02-13-2009 04:40 PM
