Old 07-14-2011, 06:16 PM
darkestdays30 darkestdays30 is offline
1999 Ford Taurus, have several questions
I have a transmission line hooked on the top & bottom of the radiator with a hex bolt that needs to come out but I don't know what size or type of wrench I need to get that out.
1999 ford taurus SES V6 3.0 overhead cam
So I'm told the transmission line pulls out of the radiator, there's one at the top and bottom of the radiator on the passenger's side, I bought a transmission cooler line remover tool, didn't do squat. I am getting so aggitated, I just want to screem! I have the radiator ready to take out except for this one issue here. Female here, first time removing a radiator, so please give me some advice. Couldn't afford the repair at a garage, I know it needs changed, there's all kinds of orange rusty gook in the opening where I took the lower radiator hose off.
Old 07-16-2011, 05:09 PM
Re: 1999 Ford Taurus, have several questions
Got it out finally. Had to break those stupid clips loose.
Old 07-16-2011, 05:37 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
G'day,
Sorry no one got back to you yesterday, must be to many people enjoying the sun
Glad you got the lines off, how is the rest of the new radiator install going?
The Following User Says Thank You to Moppie For This Useful Post:
darkestdays30 (07-23-2011)
Old 07-17-2011, 07:41 AM
I haven't bought the new radiator yet. I'm wondering if I should flush the old radiator or just go with a new one. The radiator itself had no leaks, but water was gushing out of the coolant jug, clumping up inside it, and putting on a new water pump didn't help. The radiator has quite a bit of orange clumps in it. My hoses were stomped up with that orange clump, so I removed all of my hoses and cleaned them out. Should I just get a new radiator?
I want to get my coolant jug cleaned out before putting it back on, it is stained with that orange gook. Could I put vinegar in it and let it sit a little bit, would that loosen the junk out of it?
These ford taurus cars are classic for the heat going out on them and coolant problems. My heat went out but I think it's just because the car wasn't circulating the water properly. I don't know if it's the dex antifreeze that is the issue or the mixing of antifreeze. I was pretty stupid as far as that goes, I would get cheep antifreeze from the dollar store (green) and add to it, my car is supposed to only take the orange color.
I had the car flushed, and the guy told me that I could put in any color of antifreeze I wanted to after that. But I am concerned of using dex antifreeze with the lawsuits that have been out on that. Is there another alternative I could use in place of dex that would still be orange antifreeze?
Old 07-17-2011, 12:30 PM
inafogg inafogg is offline
yes mixing dex cool with the old type(green) anti freeze will clog up the system. at this point i'd replace the radiator unless you have a rad shop to clean the old 1. if you decide
to use dexcool or the old green you'll be ok just do not mix the 2.
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
The Following User Says Thank You to inafogg For This Useful Post:
Old 07-17-2011, 02:43 PM
I think I'll go with a new radiator since it's never been changed before. Maybe Prestone extended life antifreeze, that way I get the green stuff and it's still compatible with any color.
Old 07-17-2011, 03:04 PM
just make sure you flush the system really well maybe a couple of times.
make sure that you only use the old type green anti freeze when topping off/adding
if your going to use the prestone.
if you mix with the dexcool it will sludge up again.
Live For Today
Yesterday is gone,
Old 07-18-2011, 10:53 AM
The new radiator has the plastic retaining clips in them, do I remove those before putting the transmission line through the hex nut?
Old 07-18-2011, 08:21 PM
Finally got that radiator back on!
I see why mechanics charge so much now. That's a job I never want to do again.
Old 07-18-2011, 10:39 PM
Moppie's Avatar
Master Connector
But, don't you feel a great sense of satisfaction having done it yourself?
Don't forget to flush the system a few times.
All that gunk that was in the old radiator is likely to also be in the engine.
You can flush it out by running water through the top radiator hose with the bottom one disconnected.
Or, with the engine running, disconnect the top hose, and run water into the top of the radiator.
Also don't forget to bleed the system.
I don't know if the Taurus has bleed points, but you can normally do it by running the car with the radiator cap off and watching for bubbles.
Old 07-19-2011, 05:46 AM
Well the car wouldn't have been fixed if I hadn't done that myself. $200 for my radiator, coolant jug, a new thermostat & gasket, 3 bottles of antifreeze, transmission fluid, power steering fluid, the engine coolant hose, and all that nasty stuff is out of all of my hoses. I can't imagine what a garage would have charged to do all that. Plus I got $90 off on all of my parts. I'm happy it didn't cost anymore than that, and I know it's cleaned out right.
Some of my hoses were so clogged up with orange stuff, it had formed into a rock sediment. Not hard to see why my water wasn't circulating. I was a little afraid to put money into the car, because everyone kept saying it was likely a blown or warped head gasket, but I did not have any oil in the water, and no smoke out of the tail pipe.
I flushed water out of the heater core and intake yesterday. Everything is running out clear now. I plan to flush it a couple of times today, put the coolant & distilled water in it, bleed it, then drive it and see if it's fixed or not. I know how to flush it but I don't know how to bleed it so my nephew is going to help out today. At least I will have the knowledge on how to do this later on and it won't cost anymore than just new antifreeze.
I took this car to a radiator mechanic and had it flushed out, with all of the junk that was in it, I know that was a complete waste of time. The car kept overheating. If you want it done right, I guess you have to do it yourself. If he had flushed it properly, all of that crap wouldn't have been clogged up in my hoses!!!!!!!
Old 07-19-2011, 06:00 PM
good to hear you got it,bleeding is a very simple thing to do.if there is a bleeder valve it will be in the thermostat housing.its just a screw that needs to be opened wen the engine is warm/running.open the screw until you see a stream of coolant coming out.once all the air is out close the valve & top off the system.
you may want to put a couple 100 miles in it & refush again.
Live For Today
Yesterday is gone,
Old 07-19-2011, 07:32 PM
fubard's Avatar
fubard fubard is offline
You need to refer to your owners manual for the proper coolant to use. In your case it's green coolant. From the owners manual:
Use Ford Premium Engine Coolant (green in
color). DO NOT USE Ford Extended Life Engine
Coolant (orange in color). Refer to Adding engine
coolant, in the Maintenance and Care chapter.
Manual --> http://www.motorcraftservice.com/pub.../99tauog1e.pdf
GL
Autos fixed with help from this forum:
1991 Chev Lumina auto engine hurled
1990 Ford Taurus auto death by high mileage
1995 Ford Taurus auto sold !!!
1989 Ford SHO 5 spd, sold, too finicky
1991 Geo Metro 5spd, SOLD, still ran great
2000 Chev Metro auto sold , mileage was poor
1998 Firefly 3 cyl 53mg!! SOLD I don't commute now
1993 Mercedes 300E sold...looking for a newer one
1999 Mercedes ML320
2000 Taurus my wife's new ride. Bought with only 105K
It's almost a fleet !!
The Following User Says Thank You to fubard For This Useful Post:
Old 07-20-2011, 04:47 AM
My car takes the orange antifreeze, so I don't know why that site says green. But I have Prestone extended life for all makes and models and the color is like a lime green. I do not want the orange antifreeze in it anymore.
The water is circulating through the car now without problem. The new radiator is working fine. My heat finally works (the whole time I've owned this car, I didn't have any heat).
I've done two flushes so far, and everytime you heat the car up, the water in the jug gets dark orange. Should I just keep flushing it until it becomes clear in the jug when the car heats up? Does the thermostat need to be removed if I am doing the flush after the car is hot? I figure all that stuff is coming from my engine.
Should I take off the engine block drain plug (if there is one) and run water through the thermostat housing to really get that engine clean or will it come clean with just letting it run out of the radiator drain plug? I need to get that stuff out of my engine somehow.
Old 07-20-2011, 07:12 AM
I have no idea where the engine coolant drain plug is. Would it work to take out the back freeze plug on the left side and flush the water through from the thermostat housing, or would I have to remove both freeze plugs on that side of the engine??
1999 Ford Taurus - Alternator Problems? Please help! johnosbourn Taurus | Taurus Wagon 11 05-18-2014 12:11 PM
1999 Ford Expedition (E.B. Edit.) -Loud Grinding / Crunching noise in first gear UnluckyDucky Expedition 0 03-13-2009 06:03 PM
i have a 1999 ford taurus se sport Ford_Taurus_SE_99 Taurus | Taurus Wagon 11 01-29-2007 04:12 PM
Just bought a '93 XL - Have several questions MarlboroKlingon Aerostar 2 07-25-2005 10:47 PM
Hi I'm new here today!!!!I have several questions..... AccordTypeR Car Modeling 1 05-31-2002 05:18 AM
