Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 07-14-2011, 02:22 AM
half-fast half-fast is offline
1993 Towncar: Transmission downshifts randomly
Dropped the pan and replaced the filter... cleaned out the pan and re-installed. Wasn't very dirty. I've seen much worse. Didn't solve the problem. Wife drives on the highway and the right rear caliper blows smoke.... partially locked up. SPECULATION: The brake drag was convincing the transmission that the car was "going up a hill" (under intense load) so the tranny was downshifting to compensate. Rebuilt the caliper and replaced the brake hose. Adjusted the parking brake shoes. Transmission is okay for a few days, then it starts all over again. Didn't re-check the caliper yet to see if it was locking up again. Anybody have any input on this? It's intermittent. Can ABS cause this? Or is it really a transmission issue? (I'm on a witch hunt?)
Old 07-14-2011, 08:10 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: 1993 Towncar: Transmission downshifts randomly
I would check the wiring to the VSS on the extension housing of the transmission, if it's ok you'll need to either have it scanned with a PID capable scanner to check the vss readings; it might have gone bad...
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 07-24-2011, 03:17 PM
pmpmrs@amigo.net's Avatar
[email protected] pmpmrs@amigo.net is offline
Check the gear selector mounted on the drivers side of the transmission. It's a black plastic thingy that hooks up to the shift lever, and it should move silky smooth. Mine was full of water and it caused the car to downshift randomly @ highway speeds. Replaced it and all is fine now.
Just something to check.
Mike
Old 08-06-2011, 06:29 AM
Thanks .... I'll check those items.
1993 Camry transmission skips 2nd gear mclark999 Camry/Camry Hybrid/Vista 0 07-31-2010 02:56 PM
transmission not engaging guys i need your help cyberfastpush Trans Sport 1 03-12-2010 05:58 PM
99 Venture Transmission not shifting @ high speed ul00173 Venture 3 12-17-2009 10:17 AM
Transmission downshifts and hesitations seb001 Caravan | Voyager 0 10-26-2004 07:23 PM
96 tahoe ABS light then transmission downshifts cookie420 C/K 0 09-15-2004 09:48 AM
