Go Back   Automotive Forums .com Car Chat > Chevrolet > Express | G Van
Old 07-13-2011, 11:28 AM   #1
tdowling99
91 chevy g 20 has no power wont idle
91 chevy g20 new engine 3000 miles ago ran great for a while left van idling for 30 min came out and van was dead now i have no power can barley keep it running in park no codes cap rotor plugs and wires are new just cut off cat thinking it was pluged no help
tdowling99 is offline   Reply With Quote
Old 07-14-2011, 05:30 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: 91 chevy g 20 has no power wont idle
What engine?
First test is.
Are you losing spark or fuel pressure when it acts up.
Is the gas tank empty?
Fuel filter good?
What is fuel pressure reading?
Got good hot blue spark from coil and to all plugs?
Lot of PCM circuit board shorts on them years.
Have you give it the old tap/twist test?
MT
MT-2500 is offline   Reply With Quote
Old 07-14-2011, 11:59 AM   #3
tdowling99
5.7L, ignition new at install of engine, fuel pressure good, spray pattern from both injectors good, when i try to rev up in park it bogs out even while i spray carb cleaner, i am thinking icm or pcm but i have had same problem with caprice of same year and engine and never fixed problem for more than a cupple of weeks/months at a time. i am a certified master tech and i dont know why but 91 chevys w/ 5.7 get me sometimes
Old 07-14-2011, 04:43 PM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
91 is the old breed between older and new.
They just have different bad habbits.
Like pick upcoil and ign module and shorted boad on pcm.
Good hot blue spark to all plugs.
Give the pcm the old tap twist test.
MT
Chevy Van wont start chvyvan86 Express | G Van 1 11-12-2010 08:52 AM
99 cvpi has power but wont start pauly713 Crown Victoria 8 02-23-2010 05:51 PM
Power Windows Elec Prob. Please help!! dlane85 Corsica 1 07-29-2009 11:37 PM
My car Stutters, hesitates, has a bad Idle,wont boost, or is just acting funny! eclipse98gst Eclipse Problem Diagnosis 9 03-17-2008 06:53 PM
88 Chevy 1ton w/454 wont idle, just surges! amped4life General Discussion 1 01-17-2006 01:12 AM
