Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-07-2007, 11:11 AM
eclipse98gst's Avatar
eclipse98gst eclipse98gst is offline
Exclamation My car Stutters, hesitates, has a bad Idle,wont boost, or is just acting funny!
Is your car stuttering or sputtering when accelerating. Does it Idle very rough or die when you let off the gas? Here are fixes to some very common problems that people usually ignore.
Car Stutters and Hesitates during acceleration
  • Replace spark plugs: don’t buy the expensive platinum plugs, they are unnecessary and actually make our cars run worse most of the time. Buy NGK BPR7ES plugs gapped at .028. You can buy these at most any auto parts store.
  • Check plug wires: If the sparkplugs don’t fix your problem you should look at your plug wires. Take each one off and inspect it for any melt marks or holes. If you see any flaws in any of the wires you should replace them. Depending on how modified your vehicle is you should decide whether to go with stock or aftermarket plug wires.
  • Check the MAF sensor: Make sure that your MAF sensor is plugged in, most people will install a cold air intake and simply forget to plug the MAF back in. Also make sure that all of the honey combs are still in your MAF sensor, you can check this by simply looking inside of your MAF.
Car will no longer boost like normal
  • Once again check spark plugs, wires, and MAF sensor.
  • Check for boost leaks: This is usually caused by a massive boost leak. When this happens you will be trying to accelerate and your car will feel like it falls on its face when it passes from vacume into boost. Make sure you check every hose clamp for tightness. You can check for boost leaks by creating a Leak down tester (search for more info).
  • Check for vacume leaks: Exactly as it says, check for vacume leaks. Look through the motor and make sure you don’t have any loose or disconnected vacume hose. Make sure to double check all vacume hoses leading to the the IC piping or the Intake Manifold.
Car Idles very high or very low and sometimes dies when I let off the gas
  • Adjust the BICS (Base Idle Control Screw) A.K.A. BIS or BISS: This is on the throttle body and is very easy to see. Make sure that when you adjust this by turning it your are only doing ¼ turns at a time while keeping track of how many times and in what direction you turn it so you can always put it back to its original position. Use this to fix the idle of your vehicle.
  • Check the BOV and make sure it is recirculated: If your car dies when you let off of the gas it is usually caused by not recirculating your Blow Off Valve. Make sure you purchase a recirculation kit when you buy a BOV. The only times you should not recirculate your BOV is if you have a GM MAF with a MAF Translator or if you are extremely good at tuning for rich fuel conditions at idle. If none of those apply to you then there is really no reason to not recirculate your BOV.
  • Check the O2 sensor: This is a very common problem that can cause a bad idle as well as poor running performance. You will usually get a CEL for this when it goes bad. One way to tell if it is bad is simply by smelling your exhaust, if your exhaust smells like there is a lot of unburnt fuel in it than that means your car is running rich which is usually caused by a bad O2 sensor.
These are just some common solutions to some very common problems. If these solutions do not solve your problems then feel free to post.
If there is anything that I missed feel free to add to this.
Sasan
A.K.A. eclipse98gst
Speed: a scalar quantity which refers to "how fast an object is moving." A fast-moving object (my DSM) has a high speed while a slow-moving object (your Camaro) has a low speed. An object with no movement at all has a zero speed (most Mustangs).
Old 08-07-2007, 12:58 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: My car Stutters, hesitates, has a bad Idle,wont boost, or is just acting funny!
This is good reference for nOObs. I would like to make a recommendation though. You start off spelling "idle", then switch to "idol".
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-07-2007, 01:16 PM
Good catch, spell check was not that reliable.
Old 08-07-2007, 01:37 PM
steviek's Avatar
steviek steviek is offline
sticky it I don't know how many times things like this have been asked
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 08-07-2007, 06:21 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
I love this thread right now...
Stickied...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-15-2008, 09:43 PM
97eclipseturbo 97eclipseturbo is offline
the boost leak sounds like my problem except when it falls on its face it also makes a loud squealing sound, also at the same time the problem started my cel came on. its a 97 gst stock motor/turbo with a greddy piping kit/intercooler/bov
Old 03-17-2008, 09:51 AM
churrbo98 churrbo98 is offline
anyone have an idea on why i wouldnt have spark on 2nd or 3rd cylinder? replaced plugs wired coils and icm and compression checks ok!
Old 03-17-2008, 12:45 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Check the CEL and see what codes you get.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-17-2008, 02:39 PM
2.3L_turbo's Avatar
2.3L_turbo 2.3L_turbo is offline
i just look my honey comb out of my MAF is that going to affect anything it only had the bottom one left in it so i took that 1 out. i can put it back in but is that goin to change or wreak anything?
this is whats gunna happen when u see me fly by u
1990 eagle talon soon 2 be runnin
<a href="http://s228.photobucket.com/albums/e...t=100_0316.jpg" target="_blank"><img src="http://i228.photobucket.com/albums/e...m/100_0316.jpg" border="0" alt="Photobucket"></a>
mods-
K&N air filter
Crushed BOV
MBC
Bigger injecters
oh and not to forget the new JDM Motor lol
Old 03-17-2008, 05:53 PM
i had the code read and it is maufacturer controlled fuel and air management, or something close to that, this guy was a real piece of work. anyway, i did a little more research and found something that said that my problem is likely a boost leak on the exhaust side of the turbo.... A.does that even constitute a boost leak? B. what can I do to diagnose/solve the problem? thanks in advance.
gs-t, greddy turbo piping kit, greddy FMIC, greddy type-s bov, K&N filtercharger, 17"wheels, Tokico Illumina 6-way adjustable suspension, auto with shift kit
