Old 07-12-2011, 09:26 PM
berniescout berniescout is offline
97 blazer antenna replacement
How do you remove and replace the stock antenna? I think I have a broken shield at hte base of the antenna. The two sheet metal screws hold the base mount in the fender near the ac/heater box. how do you get it out?
thanks,
bernie
Old 07-19-2011, 03:44 PM
Re: 97 blazer antenna replacement
I figured out a temp fix, and it reduced the noise dramatically, but it isn't eliminated. I disconnected the motorola coax connector and slipped a piece of braid over the cable as far as I could under the fender. I then clamped it to the cable with some large alligator clamps so it contacted the metal frame. the other end I clamped to the outside of the motorola connector with alligator clips and then jumped it to the chassis for a ground. At this time I will await a more permanent fix.
bernie
'93 lt1 antenna replacement NNY666 Corvette 2 10-03-2004 09:17 PM
1998 Blazer Antenna replacement jimban Blazer 0 01-31-2004 12:47 PM
Antenna replacement? cdipierr Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 01-04-2004 11:04 PM
Antenna replacement? cdipierr Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 01-02-2004 04:56 PM
Antenna replacement on '96 model? cathandler Audio/Security 0 03-31-2001 05:31 PM
