Old 07-12-2011, 09:06 PM
thecrow1986 thecrow1986 is offline
2002 intake manifold gasket replacement
what are all the gaskets i would need to replace the upper intake gasket? i mean whatever comes off id like to replace the gasket
Old 07-13-2011, 04:30 PM
danielsatur danielsatur is offline
Re: 2002 intake manifold gasket replacement
See http://www.Alldata.com ,
Your probably going to need new plastic coolant elbows for the belt tensioner too!
Old 07-14-2011, 11:20 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
it would help to let us know what engine your car has in it!
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 07-14-2011, 11:42 AM
02 gtp 3.8 supercharged
Old 07-14-2011, 04:57 PM
procaddytech procaddytech is offline
The supercharger is the "upper intake" on that engine. Do you mean lower intake? Most good GM parts guys know all of the gaskets, o-rings and sealer you will need for a lower intake job. Some aftermarket kits come complete. I can write up a list but it will be a while before I am back online, you question may be answered by then.
Old 07-16-2011, 10:58 PM
ok so i have the supercharger gasket. lower intake gasket. coolant tubes that run through tensioner. thermostat gasket. throttle body gasket and egr gasket. how about injector repair kits?
Old 07-17-2011, 06:39 AM
Injector o-ring kits usually aren't necessary, but if you are willing to buy a set then I would recommend them. One might tear during removal. You may know this but before you start lifting the injectors out of the intake, clean around them and spray some type of penetrating lube on the bottoms of them and move the rail around and turn each injector back and forth to work the oil in around the o-rings. They will remove much easier. Sounds like you have everything you need except for pipe sealant to seal the lower intake bolt threads that go through into the valley and a good sealant/rtv for the joint at the very ends of the end gaskets where the block and heads meet and then a little bit across the top corners of where the end gaskets, intake gaskets and intake will meet. And of course, an oil filter, oil, and Dexcool.
Old 07-22-2011, 04:41 PM
where can i find oil for my supercharger so that i can change that while i have it out
Old 07-22-2011, 07:37 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Try ZZ Performance or you can purchase it from the dealer. ZZ Performance has OEM oil and their own oil. Look under Eaton blowers and parts.
Old 07-24-2011, 08:47 AM
should my gasket set have come with o rings fir the intake? i was told there is orings that get pressed. all i have is a sealent and to gaskets. thats what came in the set
Old 07-24-2011, 09:18 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
No, gasket sets usually don't come with the two o-rings between the supercharger and lower intake manifold. Also you dont need an EGR gasket or a throttle body gasket. The EGR you wont have to remove except for the stove pipe, no gaskets there. Also the throttle body can be left attached to the supercharger when you take it apart. Unless you want to seperate them to just change the gasket. But with no leaks, I dont see the point. And its always a good idea to replace the injector o-rings.
Here is a complete list of Part numbers I used when I did mine. (compliments of Rich)
LIM Gaskets GM P/N - 89017825
Supercharger Gasket GM P/N - 24503911
Supercharger o-rings GM P/N - 24501563 (2 Required)
Fuel Injector O-rings GM P/N - 12537425
Lower Coolant Elbow GM P/N - 12565082
Upper Coolant Elbow GM P/N - 24503423
Plus of course new oil filter, oil, and coolant.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 07-24-2011, 01:42 PM
I would recommend getting your Supercharger Oil, GM P/N 12345982 oil from a dealership.
99 Windstar 3.8L Replacing Intake Manifold Gaskets dariem Windstar 8 03-21-2015 05:22 PM
Intake Manifold Gasket End Seals bjaymo3 Grand Prix 5 07-30-2010 08:29 AM
Replace Intake Manifold Gasket Stammtra Cougar 4 07-20-2010 12:13 AM
2002 Grand Am lower intake manifold gasket replacement gweak Grand AM 7 02-23-2008 06:58 PM
5.7L misfire after intake manifold gaskets replaced AKGMC Sierra 0 11-21-2003 11:58 PM
