Old 01-21-2008, 05:28 AM
gweak gweak is offline
2002 Grand Am lower intake manifold gasket replacement
I知 replacing the lower intake manifold gasket & I am at the point of removing the fuel injection rails & injectors. The service manual says to remove the rail mounting screws & just lift the rails with the injectors attached out as a set. I tried to do that, but it痴 not coming out easily & I do not want to pry it for fear of damage. Should the injectors be disconnected from the rail & removed separately? I知 not sure how the injectors are mounted to the lower intake, are they just slipped on or are they treaded? If they are slipped on, maybe I could just wiggle the injectors loose while lifting on the rail.. Any help would be appreciated.
Gary
Old 01-21-2008, 06:52 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 2002 Grand Am lower intake manifold gasket replacement
Welcome to AF!!
You don't say what size engine you have in your car but if you can get to all the intake manifold bolts leave the injectors and the rails in place. There is actually no need to remove them unless they are mounted in the head but most are located in the intake manifold itself.
If they are mounted in the head then remove the fuel rails first and then each injector should come out fairly easily. They will usually come out by grabbing them and twisting slightly. I suggest that you get a new set of O-rings and replace them before reinstallation. Also coat each o-ring with vaseline before installing the injector as this will enable them to go in easier.
Old 01-21-2008, 11:07 AM
The motor is a 3.4 litre. I am folowing the service manual instructions & did not think of just leaving the injectors in. I will check to see if I can get to all of the bolts first. Thanks.
Old 01-21-2008, 11:57 AM
Gir-_-'s Avatar
Gir-_- Gir-_- is offline
Send a message via AIM to Gir-_-
yea as long as you disconnect the fuel rail attatched to them I think you should be good just leaving them in place
04' Mazdaspeed Miata - GT2860 @ 10psi
99' GRAND AM SE V6H.O. 188whp - Sold
Old 01-21-2008, 05:22 PM
I can get to all of the lower intake bolts, no need to remove the injector or the rail. Thanks for the tip, it saved me time & worries,
Old 01-22-2008, 10:35 AM
I know I tried to avoid removing the fuel injectors, but since I知 right there should I remove & clean them? The vehicle has 125,000 miles, seems to run ok, but I知 not sure if I need to clean the injectors or not. If cleaning needed, what is involved in cleaning?
Old 01-23-2008, 07:26 AM
Pontiac Guy
Don't bother, there really isn't any way to clean them other than just wiping them off. A good bottle of fuel injector cleaner will do more good with much less hastle.
Old 02-23-2008, 06:58 PM
Big-Z Big-Z is offline
Gary
what book are you using? I need to know how to do that my self. i got a 2002 se1 with the gasket leaking, and the usuall problems, slightly rough ideling, jummping 500 rpms.
my email [email protected] please send any info you got, thanks!
Zack
