Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-12-2011, 04:02 PM
je551ca je551ca is offline
HELP - Grinding/Whirring in Jeep
Hi everyone, I'm in desperate need of some help...
I have a 200 Jeep Grand Cherokee Limited with 97k.
Today while driving (going abt. 40-45mph & with the AC on), it started making an awful grinding sound & seemed to be driving differently -- almost felt like I blew out a tire. I turned off the AC & radio to hear it better. It sounded like it was coming from the front... but it was hard to tell. It sounded awful.
I pulled over & all tires were intact. I started driving again & the sound continued.
Then, about 1-2 min. later, it stopped, felt like it was steering/driving normally again, but the engine sounded like it was whirring/whining/whistling (?). The faster I went, higher the whir/whine/whistle.
It's an automatic & was shifting fine. I got it home abt. 10 min later & looked under the vehicle. There was a slow drip of water (which was hot) coming from the front passenger area. I opened the hood & everything looks intact -- no antifreeze spray, etc. I didn't seem to be overheating. Oil pressure never changed. Water pump? Ideas?? I'm clueless...
Thanks, Jessica
Old 07-12-2011, 04:34 PM
KansasZj09 KansasZj09 is offline
Re: HELP - Grinding/Whirring in Jeep
I would think the water drips is from your AC being on, and maybe since the weather is hot out, the condensation on the AC lines is turning hot plus from the motor being hot too, thats where the drips I would think be coming from, however I aint 100% sure. As for the noise, maybe a U-Joint is bad? Have someone look at it, could be a drive shaft U-Joint or maybe one of the U-joints in one of the front wheels.
"Troubles will come, they will pass."-Lynyrd Skynyrd
Old 07-14-2011, 11:08 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Since you had your AC on, try driving without it and see if the noise goes away. AC condensers can make a lot of noise.
What engine do you have?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
4x4 full time wont engage, grinds when shifting out of dawall032 Cherokee 2 09-21-2010 08:10 PM
1984 jeep problem help crasherdude3 Cherokee 6 09-01-2009 02:15 AM
New Brake Pads Grinding Rotors HELP williamjay199 Taurus | Taurus Wagon 1 07-13-2009 11:51 AM
1999 Ford Expedition (E.B. Edit.) -Loud Grinding / Crunching noise in first gear UnluckyDucky Expedition 0 03-13-2009 06:03 PM
Front end grinding when turning and braking rlb5390 Alero 5 02-11-2009 10:19 PM
Tags
cherokee , grinding , jeep , problems , whirring
