2011 Honda Accord 3.5L Oil Change
Hi:
I need procedure, torqure specs, capacity...etc for oil & filter change for 2011 Honda Accord 3.5L. Thank You |
Re: 2011 Honda Accord 3.5L Oil Change
Warm up engine
Lift/support vehicle Remove oil cap Check oil level Remove drain plug Remove oil filter Install new oil filter Install drain plug with new drain plug washer 29ft lb (I have never torqued a drain plug in 16 years) Add oil 5w-20 4.5qts approx. Start engine, let idle a minute, make sure no leaks Shut off engine Check oil level, add as necessary(it's easier to add than drain) Check tire pressures, air filter, other fluids |
Isn't the oil type supposed to be 0w20?
I like to pre-fill my filters, if the mounting orientation allows for it. Even sideways mount I'll throw a little splash in there and let it soak into the media before spinning it on...helps oil pressure come up quicker when you start it after the oil change...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. Last edited by jeffcoslacker; 07-15-2011 at 01:06 AM. |
groovyforster what does the oil cap say? If it's 0w-20 then put in 0w-20. I haven't had a '11 V6 in yet. I know in '10 they switched to 0w-20 in some of the 4cyl's besides hybrids. |
The cap says 0w20. Thanks for the assistance.
Another thing, put as small amount of oil on the new oil filter gasket.
