Old 07-10-2011, 07:42 AM
Festivus's Avatar
Festivus Festivus is offline
CV Shaft Replacement
Got a torn upper CV boot. Noticed grease when rotating the tires and sure enough, there's a 1/2 inch hole in it. Taped it heavily with heavy duty duct tape for a temp fix.
Been reading about replacing the whole shaft. The thing is, I don't want to disconnect the steering knuckle from the strut due to the fact that I may not get it reconnected just right and the camber could be off.
Is there a way to remove the shaft without disconnecting the knuckle/strut? If I removed the hub, can the shaft fit through the knuckle?
Of course this is on the 2001 Alero.
2001 Alero 2.4 - 87k - Kid's car - Keeps me busy
2004 Accord EX V6 - 111k - Love this car
2009 Toyota Rav4 Limited V6 4WD - 26k - Wife's car
Front Drive Shaft Replacement indyhog Bravada 6 12-31-2007 09:48 AM
Crank shaft replacment JeepTrouble Cherokee 3 11-19-2005 02:21 PM
Half-shaft replace HyperV594 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 10-02-2004 08:40 PM
CV half shaft replacement process dvettman Camry/Camry Hybrid/Vista 0 09-13-2002 03:05 PM
half-shaft replacement PaulD Engineering/ Technical 4 07-15-2002 03:16 PM
