Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-08-2005, 09:18 PM
indyhog indyhog is offline
Smile Front Drive Shaft Replacement
To All;
I have recently replaced both front drive shafts to remidy a popping noise when turning (which turned out to be a bad Upper Ball Joint). If there is anyone that have some question about this procedure I would more then will to try and answer any question you may have.
BTW; Just got new shoes, A set of Bridgstones Dueler At REVO's I will post after 5k mi to give a review.
Old 11-09-2005, 04:03 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Front Drive Shaft Replacement
Welcome to the site Indyhog.
Are you refering to the shafts that drive the front wheels or the propeller shaft from the transfer case to the front differential? Regardless, your experience will be a great benefit to other Bravada people because the hard parts like axles, hubs and the like are showing up worn as many approach 200,000 miles.
Old 11-15-2005, 08:12 PM
Re: Re: Front Drive Shaft Replacement
I am refering to the shafts which drive the front wheels (CV Shaft). I can even tell you where to go for the best price for the replacement parts. If there is enough interest in it I could put together a detail power point presentation with step by step illustrations which just about anyone could follow. Then post it here if that is possible??? It would take some time though, maybe around xmas time. Let the forum vote
Old 11-19-2005, 02:57 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Which tread style did you get on the Duelers?
I got the Bridgestone Dueler HT's this summer. I like them, not as noisey as the AT tread. Good handling under a full load and when towing and good enough for most off roading. When I go camping for a week or so at a time. I'm on dirt roads and jeep trails the whole time so I drop the pressure to about 20 lbs which softens out the washboard roads then pump them up to 35 lbs when I get back on the pavement. Good sidewalls, never lost a bead yet.
Old 12-04-2005, 07:21 PM
I got the revo's
Old 12-30-2007, 07:57 PM
billbart billbart is offline
Originally Posted by indyhog
To All;
I am trying to replace the Driver's side halfshaft on my Bravada and There doesn't seem to be enough room to remove it. I have it loose, but it looks like I will have to remove the wheel humb housing to remove the shaft. Is there an easier way?
Old 12-31-2007, 09:48 AM
old_master's Avatar
Advisor/Moderator
This thread is two years old, please start a new thread.
Closed Thread
