Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 07-09-2011, 09:19 PM
BillyDCJ BillyDCJ is offline
Exclamation 96 Celica Engine pull for replacement.
I got everything ready Im pulling the engine and transaxle together and now the transaxle is hanging up on the back brace on the frame on the drivers side of the car the Haynes auto repair manual said it would pull right out ive followed every step and it will not come out any suggestions Thanks
Old 07-09-2011, 09:46 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: 96 Celica Engine pull for replacement.
Have you lifted and tilted it far enough?
The Following User Says Thank You to Moppie For This Useful Post:
BillyDCJ (07-10-2011)
Old 07-10-2011, 12:07 AM
Ok i got the engine out the floor jack under the transaxle was not letting it tilt far enough.
Old 07-10-2011, 02:22 AM
Moppie's Avatar
Master Connector
There you go
What's the purpose of pulling it out.
Rebuild, or re-engine?
Old 07-11-2011, 12:03 AM
The old engine was knocking and the rod is bad.
Old 07-11-2011, 12:41 AM
Moppie's Avatar
Master Connector
Any plans for anything fancy going back, or just a general rebuild?
Old 07-11-2011, 01:17 AM
I was just wanting to put in another engine will a 4SFE work mine was a 7SFE
Old 07-11-2011, 01:39 AM
Moppie's Avatar
Master Connector
You mean a 7A-FE?
Old 07-11-2011, 01:58 AM
yes oops 7AFE
Old 07-11-2011, 02:15 AM
Moppie's Avatar
Master Connector
Ahhhhh, could be a problem then.
The 3S and 7A use a different block. (Toyota engines are identified by the letter after number).
This means it won't be a bolt in swap.
The engine mounts, gearbox, ECU and wiring loom will be different.
You might also find the subframe and chassis mount points are also different, along with the axles, and even the radiator could be different.
Quite simply it's not a bolt in swap.
You need to put another A series engine there, and that best way to make sure it's a bolt in is to get another 7A-FE from a Celica.
Old 07-11-2011, 02:23 AM
Oh the other engine is a 4A-SE almost identical except for 1.8 litre and the 4SFE is a 1.6 litre.
Old 07-11-2011, 02:25 AM
4A-FE gosh.
Old 07-11-2011, 02:28 AM
Moppie's Avatar
Master Connector
4A-FE gosh.
Ahhh!
Should be fine then
Both use exactly the same block, just have a different bore and stroke.
Pretty sure they both have exactly the same head.
You may want to check all the engine sensors are the same, and have the same connections.
And you may want to use a 4A-FE ECU.
That said, it's going to go from a slow car, to a really slow car!
Can't you find another 7a?
Old 07-11-2011, 02:39 AM
Honestly the guy i bought the motor from told me it was an 7AFE 1.8 litre but Im learning alot and I called him back this evening and told him it was a 4AFE 1.6 he said he probably had it labeled wrong and to call him back tomorrow evening,I think my old engine could be fixed with a rod and a Crankshaft kit from NAPA it was running great just knocking.
Old 07-11-2011, 02:52 AM
Moppie's Avatar
Master Connector
A used engine will sometimes be cheaper, but is an unknown quantity.
It could be in worse condition than your old engine.
The engine code will be stamped on the block. You may need to clean some grime off it to find it.
How do you know your old engine has thrown a rod?
Have you torn it down?
If so then your half there to a rebuild, but you need to check a lot of things along the way, and make sure you replace as many parts as you can.
Replacing my '98 regal engine. Is this a good rate and engine price? bchalker Regal 1 08-25-2009 07:05 PM
93 Celica engine replacement? davev55 Celica 0 06-23-2007 09:06 AM
engine swap for 01 celica gt NER9704 Celica 3 03-01-2007 09:14 AM
Does the engine have to be pulled for pulley replacement? rstaylor Caravan | Voyager 2 02-25-2004 12:56 AM
I need advice for 1990 celica engine swap. Any suggestions TGCelica Celica 4 02-13-2004 01:58 AM
