Old 07-09-2011, 09:17 PM
dj1111's Avatar
dj1111 dj1111 is offline
P401 code
My daughters 98 Escort wagon has been throwing a P401 code for some time now. After reading several other forums I found the DPFE sensor is the culprit 95% of the time, or so they say. Replaced it and after about 30 minutes of driving it came back on, the same code. So anyone with any helpful advice out there?
I plan to remove and clean the EGR valve tomorrow as well as clean any other restricted passages. Am I going to have any problems getting the EGR with its long tube attached out of there. I looks like it may be a bit difficult. Thanks for any help.
Old 07-10-2011, 02:45 PM
dj1111's Avatar
Re: P401 code
95% of the time it's the DPFE sensor. If it sounds to good to be true it probably is. Looks like I wasted money on it. I removed the EGR and its associated tube, which was quite easy. One of the steel tubes branching off of the main tube was completely clogged. Got that one cleaned. And I ran carb cleaner through the main tube back and forth until it ran mostly clear. I was about to reassemble everything when I thought to look at the hole in the intake manifold where the EGR mounts to. Had to use a bright flashlight and a mirror. It was completely clogged with carbon. I ended up breaking several pea sized chunks out of it. Put it all back together and so far so good. Oh and if the parts store only has the EGR mounting gasket it will work for both the EGR and the tube. The hole sizes and spreads are the same it's just the outside dimensions that are bigger on the ERG one.
The Following User Says Thank You to dj1111 For This Useful Post:
denisond3 (07-11-2011)
Old 07-11-2011, 03:43 PM
denisond3 denisond3 is offline
Re: P401 code
Much thanks for providing the feedback on the fix. Its easy to forget that EGR tubes are probably half clogged on any Escort, and many other cars that have a longish tube from exhaust to intake.
I have had to clean out a few such tubes; on my mopar vehicles; I should probably check the tubes on my three 2nd gen. Escorts too.
Old 07-20-2011, 09:52 PM
dj1111's Avatar
Thumbs up Re: P401 code
Update. 10 days later and still no check engine light and it's running great.
AzTumbleweed (07-21-2011)
trouble codes danielgast46 F Series 6 04-06-2009 07:06 AM
1993 Acura integra Stereo Code Omega-Factor Interior | Audio | Security 1 03-25-2009 07:08 PM
01 Sport Trac Door Code??? levi.calhoun Explorer | Explorer Sport Trac 1 03-23-2009 10:09 PM
P401 code keeps coming back VinceH Rodeo | Passport | MU 4 12-03-2006 01:07 PM
P401 code mercurymorris Lumina 7 01-09-2005 10:05 PM
