Old 11-15-2004, 11:05 PM
mercurymorris mercurymorris is offline
P401 code
I have gotten a P401 code (EGR insufficient flow) on a 1998 Lumina. I removed the EGR valve and found the springed actuator was sticking, so I replaced the EGR valve. The code comes back within two drive cycles of clearing.
The car sometimes starts rough but runs ok after a few seconds. The mileage is 98,000. Any ideas?
Thanks
Old 11-16-2004, 03:11 AM
cadgear's Avatar
cadgear cadgear is offline
Re: P401 code
Just fixed this on my neighbor's 96 cutlass, about 80k mileage. The passage from the valve to the intake is more than likely clogged, and its nothing a guitar string/coathanger and a shot of carb cleaner can't fix. Take you about an hour, be sure you have some rags and a shop vac handy. Fortunately, this fix costs nothing but some time, and it wouldn't hurt to clean it out, so even if it is something else (MAP sensor, in this case) you didn't spend any moolah on it.
Old 11-16-2004, 03:50 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: P401 code
I agree with Cad, sounds like a clogged egr passage.
Old 11-16-2004, 03:58 PM
Re: Re: P401 code
Thanks for the advice. I'll try this ASAP. Throwing parts at a problem is expensive. $180.00 for the EGR valve.
Hope this works.
Thanks
Old 11-16-2004, 04:25 PM
cadgear's Avatar
Re: P401 code
An additional note, you'll want an assistiant or something to block the throttle open. The passage is about an inch or two inside on the right wall of the intake..you can probably feel the hard crusty crap built up on the side with your finger. Sounds strange but be careful, it is sharp and can cut you (the buildup, that is)
Old 01-09-2005, 03:48 PM
I have cleaned all the passages I can get to and no luck. I next replaced the MAP sensor and cleared the P401 code and the next time I started the car the code came back. Anymore suggestions or is it time for a professional?
Thanks
Old 01-09-2005, 06:00 PM
cadgear's Avatar
Re: P401 code
Start thinking about a $200 EGR valve then, if all the passages are cleaned and the wiring is OK.
Old 01-09-2005, 10:05 PM
Re: P401 code
Thanks,
But I have replaced the EGR valve first and the code came back. The MAP sensor was the second part and no luck.
