Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-09-2011, 04:30 PM
dagan06 dagan06 is offline
A/C Compressor sticking
I have a 96 with a 3.8 and the A/C pully is sticking. the pully doesn't spin no matter if the A/C is on or off. I just need to know if a new A/C cluch would fix it or do i need to replace the entire compressor?
Thanks
Old 07-09-2011, 05:45 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: A/C Compressor sticking
Thanks
Have you check the clutch is getting power?
It maybe something simple like a bad connection.
If it is, then it maybe cheaper and easier to replace the clutch.
If you can do it while the compressor is mounted on the car it will save de-gassing and re-gassing the system which can get expensive.
Old 07-09-2011, 06:56 PM
yeah it is getting power. It breaks free and spins every now and then.
Thanks
Old 07-09-2011, 07:08 PM
Moppie's Avatar
Master Connector
Thanks
New Clutch then
I've never worked on a Mustang (not terribly common here) but I'm pretty sure you can replace the clutch with out removing the compressor.
I have done it before, or seen it done, on other cars.
Old 07-09-2011, 07:17 PM
I'm sure I can. I'd rather pay $75 for a clutch rather than pay $200 for a new compressor
Old 07-09-2011, 07:29 PM
Moppie's Avatar
Master Connector
Hell yeah!
Could be more when you add in the cost of getting the system regassed etc.
Old 08-14-2011, 01:42 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Originally Posted by Moppie View Post
New Clutch then
It sounds as if there is too much air gap in the clutch itself (common in highly mileage systems) but not to be confused with an over charge or high line pressure.
Just to be sure its the compressor clutch, jump the pins on the ac cycling switch. Notice if the clutch engages or does not. If it does engage every time when jumping the cycling switch then you can rule out the clutch. If it does not engage, try tapping with a hammer or long rod, if the clutch then engages then you have too much air gap.
Replacing the clutches is fairly easy. If it's something you decide to to, post back and I will get you the service instructions.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Ac Compressor Question bbaker1985 Grand Prix 14 08-02-2011 04:45 PM
A/C compressor replacement jarl Trans Sport 5 12-12-2010 05:39 PM
3.5L V-7 Compressor Removal and Reinstallation krivasauto Intrigue 2 05-13-2010 09:45 PM
2005 BMW Ci Fake Stick Shift TheSixthSin 3 Series 0 05-06-2010 08:13 PM
95 Lumina A/C Compressor Noise pete029 Lumina 1 05-19-2009 03:28 PM
