Old 07-09-2011, 03:19 PM
bigrockk's Avatar
bigrockk bigrockk is offline
07 2500hd classic
Check here if your rear speakers don't work
2007 4wd 2500HD Ext Cab
Just thought I would post this for others with the same problem.
One rear speaker went out on me awhile back and recently the other rear speaker died so I decided to start looking.
Found the wiring rubbed thru and corroded at floor level just below where the handle/latch is for popping the hood. To access it properly I had to remove the plastic trim piece that runs at floor level for the length of the cab and I also had to remove the plastic trim plate that surrounds the handle for opening the hood. Found two wires "open" one was blue and the other one was brown and both were part of a twisted pair. Repaired them and all is working now.
Hope this helps someone with the same problem!
The Following User Says Thank You to bigrockk For This Useful Post:
speediva (07-09-2011)
Old 07-09-2011, 08:43 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Re: Check here if your rear speakers don't work
Thanks for posting this! I'm sure it will help someone who is stuck wondering why the rear has no sound.
Any other tips or advice?
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 07-10-2011, 08:53 AM
j cAT j cAT is offline
THE WIRES in this area come with electrical tape wraping and or laid in a plastic trough...
your saying the wires did not have any sheathing protecting them ..this is very important finding as this , if fabricated throughout the vehicle could be a saftey / expense costs issue.
Old 07-10-2011, 09:38 AM
bigrockk's Avatar
07 2500hd classic
They did have a wrap of tape around them but that had worn thru. Where the insulation on the wires had worn thru it turned the copper green and corroded. When I found the bad spot the wear in the wire was about the size of a pin head but the wire inside had corroded away. I had to cut back about an inch either side of the wear spot to find clean wire.
Old 07-10-2011, 11:48 AM
your vehicle is 4yrs old and this is very odd that this occured...wearing thru the tape and wire insulation...
copper and steel touching with some road deicing chemicals will rapidly destroy the metal..
make sure the wire harness is not in a position that you can step on it...or it can move.
Old 07-11-2011, 09:50 AM
bigrockk's Avatar
07 2500hd classic
I agree it is odd after only four years, that being said the truck does have 210,000 km on it.
I did place the wires back to their original position and vaccumed all the dirt away from around them, hopefully it lasts awhile!
Old 07-11-2011, 11:28 AM
since you have the newer body style I am not sure on why this dirt can get to the wires laid in the channel running to the rear..
my 2000 silverado ext cab has 135,ooomi which is about 210,oookm and this has never occured to me that dirt soils road grit got to the wires..
perhaps you need better floor mats with deep voids to capture all this debris your foot wear tracks into the vehicle....
hard to find quality floor mats lately..my matts are 11 yrs old....
Old 07-16-2011, 02:30 PM
bigrockk's Avatar
07 2500hd classic
I bought the truck about a year ago and it was used as a work truck so maybe that is why the mud and dirt got into places it shouldn't be?
The truck has no carpet just the factory vinyl floor. I use deep floor mats as well, so hopefully that should do it.
Old 07-16-2011, 09:11 PM
I see this is new to you ..
could be a flood vehicle...carfax can find info about your vehicle...
this issue is not normal..
Old 07-20-2011, 12:42 PM
bigrockk's Avatar
07 2500hd classic
Not sure I want to know..lol
Actually I did have a dealership run a history for me and the truck was purchased at an dealership close to where I bought it, and by the looks of a few warranty issues it stayed in the area until I purchased it, that being said I knew the truck was used by a guy who contracted to the oil and gas industry. A lot of the well sites are extremely muddy and I am pretty sure this is where all the excess dirt and mud came from. I got the truck for a great price but knew that it most likely had a hard life before I got it. It did have a very good history of regular maintenance though.
Old 07-20-2011, 03:11 PM
I guess that explains all the dirt inside the vehicle...if the windows where left open during rain storms that would add to this getting into areas not normally fouled by foot debris...gas/oil extraction areas are very muddy..
Old 07-21-2011, 10:15 AM
bigrockk's Avatar
07 2500hd classic
Good point about the windows, I never thought about that but it makes sense!
1998 P71 rear speakers don't work. Moose666 Crown Victoria 0 06-26-2009 06:14 PM
Rear Speakers Don't Work. chipthief Car Audio 0 08-02-2008 11:34 PM
1997 Trailblazer Rear Speakers Don't Work bmonier Problem Diagnosis 5 04-01-2007 11:54 PM
Concert sound rear speakers don't work swanny723 Century 1 02-21-2005 07:27 PM
Front speakers don't work LATAWIEC Audio/Security 0 09-02-2003 01:33 PM
