Old 07-08-2011, 04:55 PM
Motojojo Motojojo is offline
Simple question about ac ports... Hopefully
I have a 93 lumina it is a flex fuel one was trying to locate the ac service ports and all i can find are two lines running from condenser to evap can and radiator... I just need to know we're do i fill the system at i've done it in other cars so i know what they look like but just can't find them
Old 07-08-2011, 05:30 PM
romeguy1 romeguy1 is offline
Re: Simple question about ac ports... Hopefully
I have the same question, only mine's a 97 Lumina. I can find one tucked away behind the battery and below the air filter. But I think it's the high side, the charger fitting won't fit on it.
Old 07-08-2011, 10:36 PM
Just wanted to say I found them and for you romeguy if yours is like mine you can see one from the top and one if you look up from under the car in the same area and thank you for your post it is what made me look there in the first place
Old 07-09-2011, 11:02 AM
danielsatur danielsatur is offline
The low pressure side is larger and close to the compressor.
Simple Question About Fluid Specs x1yyx Vitara 2 11-28-2005 08:50 AM
a simple question about someones car.... talonpunk831 Off-Topic 5 04-08-2005 10:39 PM
simple question about my doors Brooksie Tiburon | Tuscani 1 03-29-2005 02:49 PM
just simple question about b16a1 wiring scorpioq Engineering/ Technical 0 03-24-2005 09:52 PM
Just a simple question about primers. 4x4 Cactus Car Modeling 4 01-30-2002 03:07 PM
